Old 02-01-2023, 03:52 PM   #1
2019 25' Flying Cloud
Pala , California
Fresh Water Tank Management Question
Hi,
I'm staying outside of Yuma. A bit salty water as Yuma is famous for. It's fine for most things but not drinking. So I filled up FW tank with good water and will use that for Berkey till empty....then what?
What's the best way to keep the tank healthy till I can get to a good FW source?
I don't think leaving "empty" a good idea as no way to tell if empty and a dark damp environment just begging for mold!
I'm thinking just fill and dump every few weeks.....
The tank was recently disinfected with bleach as maintenance so good to go.
trav
TravisH is offline   Reply With Quote
Old 02-01-2023, 04:37 PM   #2
Lily&Me's Avatar
Normal , Illinois
Buy some gallon jugs of water and use that for drinking, coffee, tea, etc., and conserve using tank water for flushing and dishes.
Supplementing what is in your tank with store-bought water should get you thru.
Maggie
Old 02-02-2023, 06:36 AM   #3
1994 30' Excella
Mississauga , Ontario
Putting the local water in your tank won’t harm it. Like Maggie said use bottled for drinking and tank for everything else, then rinse out when you relocate.
Al and Jean
TAC ON-3
Old 02-02-2023, 07:48 AM   #4
1986 31' Sovereign
Miami , Florida
I pretty much always use my onboard pump and built-in tank, filling the tank as necessary. This does a couple of things — it keeps the water fresh in the tank as it is constantly cycling in and out and, should I sprout a leak, especially at night, the pump coming on will almost certainly waken me. I simply shut the pump off before leaving the trailer so no flooding in my absence.
In your case, I would simply carry on doing what you are doing. Eventually, you will be somewhere with better quality water and by using and refilling your tank, you will eventually purge the system.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 02-02-2023, 07:56 AM   #5
Mollysdad's Avatar
I keep the tank at 20%.
Enough for a few showers and dish washing until I get somewhere with city water.
I see no need to drag 800# of water behind me.
Old 02-02-2023, 07:58 AM   #6
dznf0g's Avatar
Oswego , Illinois
Unless your destination that day is several days of dry camping/boondocking.
-Rich-
Old 02-02-2023, 09:28 AM   #7
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay , Florida
Maggie
This is what we’ve done for the past 30 years. We still clean the fw tank periodically with a bit of bleach too even though we don't drink from it. Since we carry a 5gal igloo in our tow vehicle we usually buy bags of ice and keep that topped off and that way we usually have ice and drinking water all the time. Haven’t ever had an issue.
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
369goose is offline   Reply With Quote
Old 02-02-2023, 11:50 AM   #8
2017 23' Flying Cloud
Hampden , Maine
This is certainly not for some who must rely on all water sources for long trips, but we don't ever use the fresh water tank for drinking, only for all other uses. A bit of salty water for washing dishes, showering, etc. does no harm. We also use 2, 5-gallon coolers + ice for drinking water--from our well before we leave home, and and filling them from good city water sources for extended trips. We also do the routine of spring and fall (& in-between, if necessary) bleaching and rinsing the entire system.
airmaine is offline   Reply With Quote
Old 02-02-2023, 06:13 PM   #9
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
We have found that the multi layer filtered water fountains in Walmarts (Primo brand) sold at 39 cents per gallon does it for us. We carry five and three gallon containers and it will last us the week. As for the fresh water tank, it's used for all other uses.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 02-03-2023, 07:37 AM   #10
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We use a Britta water filter for drinking water from our tank if we haven't filled it from our home water. Worked all through Alaska and western Canada last summer. Carry an extra filter in case one gets clogged...
Kay
Old 02-03-2023, 06:10 PM   #11
Pala , California
Thanks all,
I have the drinking water all figured out.
I'm wondering how to keep the tank healthy without cycling through the water.
I guess the question is
"how long can we store a full tank, 38 gallons, of water for?"
Trav
Old 02-04-2023, 07:13 AM   #12
TrvlngTinTin's Avatar
2022 30' Globetrotter
Erie , Colorado
My 2 Cents :-)
I Have seen on multiple occasions where a restaurant, or gas station, or multiple customers providing a soda fountain dispenser. Over Filter the water and start algae to grow down stream of water filter . So I will,
keep nice chlorinated water fresh.
Change out weekly. Our ad a dash of bleach. I have added in past recommend dose of camco water fresh. And I believe to much is not good for plastic? And pump.
And use Bretta filter and dispenser.
I’m also using rv antifreeze in tank during winter and through system to keep bacteria to start growing.
Then in summer first stop full hook up for flushing.
That’s just my 2 Cents.
Happy Travels
Tin tin
TrvlngTinTin is offline   Reply With Quote
Old 02-04-2023, 09:50 AM   #13
OrangeCrush's Avatar
2017 25' Flying Cloud
Longmont , Colorado
We too do not drink the water from the fresh tank but instead use 2 Aqua Bricks with a spigot. They are 3 gallons each and fit perfect under the curb side dinette seat cabinet in the 25FB. We went to them after having some cheap plastic ones break on bouncy I70 in Colorado which was a mess.
https://saganlife.com/product/aquabr...ks-and-spigot/
OrangeCrush is offline   Reply With Quote
Old 02-04-2023, 11:57 AM   #14
"Cloudsplitter"
Maggie
Yep...have 8 1gal plastic jugs we fill at home with 3 stage filtered water.
I will NOT compromise my Coffee making...
Old 02-08-2023, 04:37 PM   #15
Steamguy's Avatar
2019 27' International
Washougal , Washington
Originally Posted by Minno View Post
We use a Britta water filter for drinking water from our tank if we haven't filled it from our home water. Worked all through Alaska and western Canada last summer. Carry an extra filter in case one gets clogged...Kay
^^THIS. We used this method for over 20 years in our SOBs before getting our Airstream. As long as you're filling from a municipal source, you are assured of healthy water, no matter how it tastes. That's what the Britta is for. Always made coffee and cooking water from the Britta.
Originally Posted by TravisH View Post
...how to keep the tank healthy without cycling through the water...how long can we store a full tank, 38 gallons...
As long as you've filled from a municipal source, you can keep the water pretty much all summer. The chlorination will generally last, unless it's really hot.
But what you want to be careful about is filling from a non-municipal source. No guarantee of chlorination. We found out the hard way one year. Went camping in the spring, filled the tank with water from this really great-tasting source, not realizing that it wasn't chlorinated. Super-hot summer. Didn't go camping again until very late fall. What came out of the faucets at that time looked AND SMELLED like it came from the set of Ghostbusters.
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 02-08-2023, 06:47 PM   #16
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
The chlorination in city water will not stay in the water very long - perhaps a few days to a week at best. In some circumstances it will evaporate in less than a day. The taste might still be there after that, but not the protection from the chlorine.
We have a well, and I've had water from my well in the fresh water tank for months with absolutely no problems. City water vs. well water isn't the issue. The issue is clean water vs. contaminated water.
Richard
11018
richard5933 is offline   Reply With Quote
Old 02-13-2023, 09:10 AM   #17
1972 25' Tradewind
East Lansing , Michigan
Does this mean you also don't cook with the tank water, since you don't drink that water?
SnowWanderer is offline   Reply With Quote
Old 02-14-2023, 08:46 AM   #18
369goose's Avatar
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay , Florida
Correct. Not at all for consumption. Either bottled water or fresh clean ice in our 5 gal igloo to consume/cook.
☘ 369goose
Old 02-14-2023, 09:53 AM   #19
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
If a person is going to shower with water from the fresh water tank, that person may as well drink it too. Showering produces aerosols (think mist, steam, drioplets, etc.) which can very effectively carry bacteria, etc. into lungs, eyes, and mucous membranes.
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 02-14-2023, 11:09 AM   #20
dznf0g's Avatar
Oswego , Illinois
For sure!!! If one maintains their water system properly, there is no reason not to use it for drinking. Three trailers over 40 years drinking out of the tank...no one in family with any upset biology at all. I sanitize once, maybe twice a year. Never let water remain in tank for more than a week.
-Rich-
Using fresh water tank to rinse black water tank SpikePoet Waste Systems, Tanks & Totes 17 01-04-2023 06:47 PM
Filling fresh water tank 2019 airstream fresh water fill problem arvaterry General Repair Forum 7 06-01-2022 08:44 PM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 07:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Campgrounds with bathrooms, campsites without water, and gray water management? Piggy Bank Boondocking 21 10-14-2015 03:29 AM
