Old 02-13-2020, 09:55 AM   #1
Toronto , Ontario
Fresh water tank emptying too fast
We would so appreciate insights from those of you who are far more experienced and understand the big picture layout of the land.
We're in a 1975 rebuilt 31 foot Land Yacht. Original tanks. We have a mystery with the fresh water tank emptying far too fast. Filled it completely yesterday. Based on our approximate time to fill (28-30 minutes) we estimate about a 50 gallon tank. That's a lot of water. Fill was completed early afternoon. To stimulate what we would do while boondocking, we used only the water from the fresh tank for prepping dinner, washing hands, etc. We are cautious with our water use - not running it ongoing but only sporadically. No showers. Only a few toilets flushes. By this morning, the tank was empty. We absolutely did not use 50 gallons of water in one afternoon. We have noticed quick emptying over the last few weeks but yesterday was a clear test. There are no leaks that we can see under the trailer.
As a separate (but possibly related) issue, our grey tank is filling up extraordinarily fast. We have to keep it open all the time if we don't want water in the shower pan and oozing up the floor. This could be related, however the first time this happened (first night we were clear of freezing and therefore turned on the water), we were hooked up to shore water and it flooded within an hour, after only a little bit of hand washing, and dinner prep. We have been doing endless tests to try to isolate the problem as we're yearning to dry camp and boondock. We can't however until we figure out how to maintain our fresh water and not fill the grey so fast.
Any words of widsom??
TzNan is offline   Reply With Quote
Old 02-13-2020, 10:02 AM   #2
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Do the tanks share a common vent? Any chance water is draining from one tank to the other via the vent?
BambiTex is offline   Reply With Quote
Old 02-13-2020, 01:24 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When your fresh water tank ran out of water, did you open the drain to see if there was any left in the tank? We had a 75 that always had about 8 gallons in the tank that could not be pumped out. My theory was that the output line in the tank was damaged. Since the tank was 45 gallons and 37 or so was available, I did not pursue the issue.
Richard
Old 02-13-2020, 02:08 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
FWIW
I found that when I jacked up the street side while winterizing. The drain was open and continued for a good 2hrs.
Bad design.🥴
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire"
Amanamus
Tahawus....🌥
Old 02-13-2020, 02:42 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
The fresh water plumbing and tank are not connected directly to either the gray or black waste water systems.
If you are not using the water, there must be a leak in a fixture that is letting water pass through it.
ps:
Some 1975 models had a Mandaville (?spelling?) Dish Washer. It was not a real automatic dish washer. It was a hose that attached to a soap reservoir then to a wand, which was an attachment used while soaping or rinsing dishes. If you have/had one of those, look under the kitchen sink to see if there is a water line that is not connected as it should be.
Alan
Old 02-13-2020, 09:04 PM   #6
Toronto , Ontario
ps:
Hi Alan - thanks for your thoughts. We had a complete rebuild of the trailer down to the frame so we don't have one of those hoses and no water line seems to be out of place or disconnected. It is our thought as well however that the fresh water has to be going somewhere. Is it possible that it is sitting somewhere in the belly? (BTW - The tanks are one of the few original parts). Our builder is also perplexed.
Old 02-13-2020, 09:07 PM   #7
Toronto , Ontario
Originally Posted by ROBERT CROSS View Post
FWIW
Bad design.🥴
Bob - does this mean that water was sitting in the belly somewhere?
Old 02-13-2020, 09:08 PM   #8
Toronto , Ontario
Thanks for the mention of this Richard. Yes we did check the drain - there was nothing substantial left in the tank.
Old 02-13-2020, 09:11 PM   #9
Toronto , Ontario
Hey BT - this is a good question and an unknown right now. We'll talk to our builder to see what the layout of the venting is or we'll try to trace it ourselves. Still there is the issue of where did all the extra fresh water go? The grey tank can't hold it all and wasn't overflowing when we woke up in the morning and 50 gallons were gone. Remains a mystery??
Old 02-13-2020, 10:14 PM   #10
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Do you leave the water pump switch "on" all the time, or switch on when needed and then off when finished using water? Can you hear the pump running? It the grey tank filled up that quickly while on city water, I suspect that there is a plumbing problem, or you have a massive leak in one of your taps or shower that is dumping water into the grey tank. If this is a "rebuilt" rig, it is quite possible that the plumbing has been incorrectly replaced. Only option is to follow every line to see where it goes. Start by looking below the sinks and see if there are any strange looking lines going into the drains. Is the trailer centre bath or rear bath?
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-14-2020, 04:06 AM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Recheck the volume of the tank
Old 02-14-2020, 06:16 AM   #12
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I don't think the tank could hold anything near 50 gallons. Fill it and empty into a bucket to see what is in there.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 02-14-2020, 06:43 AM   #13
1970 27' Overlander
Liberty , North Carolina
We have a 1970 Overlander with the 50 gallon fresh water tank.
Try this, empty the grey tank. Fill the fresh water tank, turn on the pump and pressurize the system . Stop, do not turn on any water at all. Wait, if the pump starts cycling you probably have a leak. If the grey tank fills, and the fresh tank empties you definately have a leak.
Suspect the vent system as well on the grey tank.
B Wilson is offline   Reply With Quote
Old 02-14-2020, 07:31 AM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You should be able to go 5 days to a week with the water use you describe. I can not imagine a belly pan that would hold water and not drip. One place that water could go is through the check valve and out the inlet hose. But it looks like you would notice that. My logic says that you are pumping water through a fixture and into the gray tank. I do not see how tank vents would affect this problem at all. Either a leaky fixture you have not found or a mis plumb by the builder? Do you have a tankless WH? Or any special equipment that might have a line directly to the gray tank that does not go through a visible faucet?
Old 02-14-2020, 07:44 AM   #15
2019 25' International
Providence , Rhode Island
Stop guessing on the input side and buy this:
kittmaster is offline   Reply With Quote
Old 02-14-2020, 09:23 AM   #16
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you dumped 40 or so gallons of water, it didn't just vanish. It very much went somewhere and left traces of where it went. If it leaked, it's dripping out of the trailer somewhere. It's not just sitting in limbo.
Gray tank volume is just as "suspect" as any other tank. Use a hose and flow meter (like the Amazon one above ...) or a bucket to see how much it holds.
Old 02-14-2020, 09:39 AM   #17
1976 31' Excella 500
Chappell Hill , Texas
Fill the fresh tank. Then open the drain and drain 5 gallons at a time until empty to see how much you really have.
tbashin is offline   Reply With Quote
Old 02-14-2020, 11:19 AM   #18
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
I have seen black tanks fill because the toilet flush valve seal was leaking. But, no grey tanks mysteriously filling. There must be a faucet leaking into a drain to the grey tank. Did the '75s have a grey tank?
guskmg
Old 02-14-2020, 12:12 PM   #19
2002 25' Safari
Dewey , Arizona
Images: 62
75s had grey tanks, but th hey were very small. My TradeWind had 12 gallons.
The fresh water tank had vents on the top to allow air to escape when filling. There were two. One on each side of the cross member that ran across the tank.
Richard
Old 02-14-2020, 12:15 PM   #20
2018 25' International
Slidell , Louisiana
I concur with this assessment as the most likely. Further supporting this idea is that siphoning can occur in the fresh water system so it is not required to have positive pressure to have it drain into the grey if there is a pathway.
Is there an internal tank flush feature on that model? What about a water pipe winterizing drain that flows to the grey tank?
Brian
Black Tank Valve Stuck in ON. Tank not emptying. eyechip Sprinter and B-van Forum 3 09-25-2018 10:07 PM
Emptying fresh water tank Tschupp Water Heaters, Filters & Pumps 18 01-17-2018 06:18 PM
Fresh Water Emptying/Leaking Out Bottom Davis Effect Waste Systems, Tanks & Totes 7 11-24-2016 07:12 PM
Emptying Water Heater Tank for Storage jamieb1086 Water Heaters, Filters & Pumps 4 05-31-2016 11:09 PM
25 Foot 2014 FC steps for flushing and emptying black water tank DogGonnit Airstream Trailer Forums 5 09-15-2014 05:28 PM
