Old 07-07-2020, 03:25 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Fresh water tank drain
I thought that by now Airstream could have come up with a better way. My older trailer (1985) needed a new valve some years back and I struggled through it then. Luckily it had an access patch so I didn't need to cut one. But what a PITA is was to replace. My big hands just didn't make the job any easier but I did get it done. Now some years have passed and our current Airstream is 16 years newer and I'm working on a leak in the short hose between the tank and valve. I have a new valve to install while I'm at it for good measure. I had hoped that in the 16 years they would have made a better mousetrap but NOooooo. Same ole, same ole. Fortunately this one also had a access patch but installed with regular steel screws. Had to grind the heads off. Then had to fight with the clamps. One easy one not so. Oh well. I plan to attempt a modification that hopefully will make the job easier for the next attempt.
Boy I sure feel better now having vented.
ThanX all. Stay healthy and see ya on the road someday
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-07-2020, 03:49 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
We did it 12yrs ago...did it with a set-up that will last.
Semper-fi
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Worry...a brain exercise done when it really wants to sleep"
RLC
Tahawus
Old 07-07-2020, 04:30 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
Hereís how I did it.
ID:	372171   Click image for larger version
ID:	372173   Click image for larger version
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 04:44 AM
Fresh Water Tank Drain NEW94 Fresh Water Systems 5 11-04-2007 08:58 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 07:50 AM
