09-23-2023, 11:55 AM
2015 23' FB International
vancouver
Fresh water tank bulging
Hi, This is my first time on the forum. I am having an issue with a bulging fresh water tank on my 23' 2015 BF International. The metal housing for the fresh water tank is bulging in the middle. The bolts are still secure to the under belly of the unit, but the bottom is bulging about 2" in the middle.
I had it looked at by a dealer. They want to pull the housing out. Sounds costly.
09-23-2023, 12:52 PM
1993 34' Excella
Estancia
, New Mexico
Some bulging with a full tank can be normal. Water tanks can be overfilled which can cause bulging. Is your tank full? Try draining a little.
09-23-2023, 02:51 PM
1995 25' Excella
xxxxx
, xxxxxx
Clogged vent?
09-23-2023, 03:29 PM
LEV ZEPPELIN
2004 19' International CCD
Chicago
I agree. Check the vent. It's a small ~1/2" round opening cover (at least in mine) with a little screen. Mine is located next to the main filling opening. A lot of pressure can build up.
When you top off the water tank, do you see water coming out of this vent?
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
09-23-2023, 05:37 PM
2018 27' Globetrotter
Mooresville
, North Carolina
I had a post regarding this and wondering if my fresh water tank was compromised. See the follow thread;
https://www.airforums.com/forums/f44...ed-229879.html
Later I ran across another thread by GMFL (Airstream Nuts and Bolts Airstream shop in Alabama) that showed another way to support the tank if you felt it needed, or wanted, addtional support. See below;
https://www.airforums.com/forums/f44...ag-217498.html
To summarize, it seems a sag on the side near the fresh water drain is normal. However' GMFL has seen some of the Classics have fresh water tank failures as those tanks are 50+ gallons vs the normal 39 gallons in my 27' Globetrotter.
I felt GMFL's support was something I could handle to add some additional support even though what I have appears to be normal. Basically, you hang some U-bolts across the front and rear axles and join them with a steel strap. The steel strap is painted black to keep possible dissimilar metals from contact. It was a relatively easy mod to do.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
09-23-2023, 09:29 PM
2014 27' Flying Cloud
2023 30' International
Las Cruces
, New Mexico
Ours was caused by over filling
We used to have a 2014 FC 27FB and noticed our fresh water tank cover was bulging. It was right after I filled the tank, got called away and when I came back the water was flowing out the inlet where I had stuck the hose in. My opinion was that the overflowing for about 10 mins, caused pressure build up. The built up pressure likely expanded the tank out causing the cover to deform.
Hope this helps
09-24-2023, 06:10 PM
Loco Airstreamer
1970 23' Safari
Denton
Speaking of freshwater tanks ... where can a vintage owner find these to purchase? The new one I purchased sat around for awhile before I got around to installing, and it turned crispy and shattered in a gillion pieces when I moved it.
09-24-2023, 08:40 PM
1968 20' Globetrotter
Montrose
Vintage Trailer Supply has lots of tanks. I got one for my 68 Globetrotter.
09-25-2023, 09:44 AM
vancouver
Thanks for the feedback. You given me a couple great ideas for a fix.
09-26-2023, 02:27 AM
Loco Airstreamer
1970 23' Safari
Denton
I think those tanks come from one original source and are sold through multiple outlets. My last one never got used. It sat waiting to be installed - for a long time, and apparently that sitting (in Texas heat), and when I was moving some things around where it was stored, something hit it and shattered it. Yup. Shattered shattered. That is slowing my buying process this time around. That and the price doubling.
09-26-2023, 06:14 PM
2019 22' Sport
High River
, Alberta
UV exposure was probably the issue. I had the original waste tanks out of our 1975 trailer back in 2011, and I was very happy with their condition.
09-27-2023, 07:28 AM
Loco Airstreamer
1970 23' Safari
Denton
I bet that is right.
