Old 04-29-2022, 06:24 AM   #1
Swagman's Avatar
2010 25' FB International
Lymington , Hampshire
Send a message via Skype™ to Swagman
Fresh Water Pump Start Up
Hi Guys. Couldn’t work out how to delete this from General Repair thread so repeating it here.
We’ve a 16 yo International and can’t resolve what seems to be a small problem. Hoping someone can help.
Our 12v water supply switch has 3 choices. Internal, External, and Fill.
The pumps work fine on External and Fill, but not when switched to Internal.
The two pump fuses I can find (on the power supply / charger) , appear ok.
Is there another fuse somewhere that I’m missing?
Could the switch itself be faulty?
Is it common for a pressure cut out in the pump itself to fail - perhaps stuck in the ‘pressurized’ mode?
Any guidance on where’s best to start sorting this would be much appreciated. Thanks in anticipation….
Don't take life too seriously, not many of us are going to make it out alive!
Swagman is offline   Reply With Quote
Old 04-29-2022, 06:46 AM   #2
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Hi - I removed the other thread so you won't have duplication.
I'm no help with your problem...our water pump is strictly for using the internal fresh water supply. External or "City" water supply is pressurized from the incoming water source at the "City Water" inlet. To fill the internal fresh water we manually open the "Fresh Water Fill" door and put a water supply hose in it. So we've got separate "Water Fill" sources, where yours sounds as if it runs off one for the same chores.
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 9 08-11-2023 10:52 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 14 01-20-2023 05:44 PM
Using Campground Fresh with Camper Fresh Pump On Karen-Mike Water Heaters, Filters & Pumps 25 05-27-2020 10:37 PM
Can't get water to pump from fresh water tank xbr443 Fresh Water Systems 6 01-20-2015 07:34 PM
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 08:00 PM
