Old 09-07-2018, 09:03 PM   #1
1991 34' Limited
Tucson , Arizona
Fresh Water Large Drain Plug Leak
On my 34í 1991 Limited there is an access panel behind the second wheel. Removing the panel reveals a large drain plug in the freshwater tank. When I turned on the auto fill switch water rushed out of the access panel so I removed it to find the large drain plug leaking badly. Tightening the plug did not fully stop the leak. I removed the plug, wrapped it with Teflon tape, and put it back in tightening a few turns by hand and then with a makeshift socket. When I turned on the auto fill there were about six drips per second. Tightening the plug reduced the number drips to once every three seconds, but I canít get them to stop. Iím afraid of tightening the plug all the way into the tank! The water seems to be coming around the threads as itís dry on the outside of the plug receptacle. I canít see a visible crack or feel any kind of crack in the plug receptacle but I do feel a small split in the plug itself. Iím not sure if thatís part of the manufacturing of the plug or not. Any ideas on how I can stop the leak?
ID:	321803   Click image for larger version
Hikingsolo is offline   Reply With Quote
Old 09-07-2018, 09:48 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
I would remove the plug completely and clean the tank and plug threads with a toothbrush. Check the tank bib for cracks. If no cracks, then use pipe dope (Teflon paste) on the plug threads and re-install the plug. Use a good amount of paste.
Old 09-08-2018, 06:48 AM   #3
1991 34' Limited
Tucson , Arizona
Thanks for the suggestion. Is Teflon paste a material that will need to set up for a while before water is added to the tank? I’ve used gas pipe three sealant but not anything for potable water systems.
Old 09-08-2018, 07:23 AM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
No it does not have to set up and it I’d available at any hardware store in the plumbing section. It works and a sealant and lubricant filling in micro gaps while screwing plug in place. It drys to a putty consistency and I believe it to be superior to Teflon tape on plastic threads. Plastic threads do not have the strength to cut into the tape and that only causes more potential for leaks.
Old 09-08-2018, 07:26 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
In my experience, I have found the plug will shrink over time. Ive had a couple do this. The only remedy is to buy a new plug from Airstream. The new style is made of black plastic, not the yellow.
Old 09-08-2018, 09:35 AM   #6
Silvr_Bullet's Avatar
42į 2' 27" N / 74į 7' 6" W , US
Did you try adding additional layers of Teflon tape?
Silvr_Bullet is offline   Reply With Quote
Old 09-08-2018, 10:32 AM   #7
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Having just replaced a fresh water tank I'm with GMFL. Atomic could also be on to something... I'd certainly replace the plug based on his experience. Airstream currently uses a non-hardening pipe thread compound on both threaded fittings and slip joints on the fresh water tank. I'm not sure what brand they use, it's light green. My Airstream dealer parts guy didn't know either, but said their service team uses a widely available commercial product. After researching the subject, I used RectorSeal T plus 2. So far, so good. Use it liberally... you want it in every nook and cranny of those threads.
GammaDog is offline   Reply With Quote
Old 09-08-2018, 10:57 AM   #8
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Again the plastic threads are not really strong enough to cut into the tape.
Old 09-08-2018, 11:05 AM   #9
harryk's Avatar
2005 31' Classic
Venice , Florida
Get a new 1 1/2 inch plug from lowes or home depot. I found some with more thread area which means that the plug was actually about a 1/2" longer and it had a wrench end instead of the hole. Then teflon tape....clockwise. Near the wrench end I put 10 wraps and tapered towards the other end. The 10 wraps is key.
While you are there, consider putting a fresh water hose thru the hole and move it around to clean. You are gonna get wet but your tank will be clean !
harryk is offline   Reply With Quote
Old 09-08-2018, 11:18 AM   #10
If you need To go the route of a new plug I would bring the old with you, the same thread pattern is important in addition to the 10 wraps of Teflon tape, when I wrap it I will do near the most it will hold on the threads, tapes cheap do it a couple of times with tape till it feels snug not loose when you hand tighten it.
Old 09-08-2018, 10:45 PM   #11
1991 34' Limited
Tucson , Arizona
6 layers. I’ll try the paste. A local guy suggested both. Tape then paste.
Old 09-08-2018, 10:46 PM   #12
1991 34' Limited
Tucson , Arizona
Thanks for the specific name!
Old 09-08-2018, 10:50 PM   #13
1991 34' Limited
Tucson , Arizona
I wondered if the plug was metric since the hex head was metric. I thought about going to
Lowe’s/Home Desperate but the local stores are somewhat sketchy. My local RV place was no help. A call to Airstream may be next if the tape and paste don’t work.
Old 09-09-2018, 05:50 AM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Harryk,
The thread pitch is different on the plugs fromthe hardware store, I suspect you might damage the tank side threads, or worse crack the bung.
Old 09-10-2018, 07:29 AM   #15
harryk's Avatar
2005 31' Classic
Venice , Florida
Both the tank, the old plug, and the new plug are NST....national standard pipe thread.
Large fresh water tank plug-removal erikk Fresh Water Systems 0 06-22-2012 04:58 PM
medium, large or really, really large batteries bukib Land Yacht/Legacy Motorhomes 3 11-14-2010 10:00 PM
Where is the fresh water drain plug located? bambid Fresh Water Systems 10 06-24-2010 08:47 PM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Tool to remove fresh water drain plug willbrackman Fresh Water Systems 5 06-19-2009 10:44 PM
