Old 09-27-2023, 01:10 PM   #1
2015 27' Flying Cloud
Stillwater , MN
FResh water drain valves on 27fb FC
Where are they? Im such a noob and I cannot find pictures on the web or videos.
Do I even need to drain the fresh water and the water heater system if I keep the unit heated via the furnace at nights and leave the water heater ON.
My unit is in northern Nevada and I am heading to St. George in Mid November. Weather here is very crazy with huge temperature changes in the High Intermountain desert. From now(late Sept) to our departure to st. George we will not be needing to use fresh water or septic systems, we will just be sleeping in the RV.
Kepano is offline   Reply With Quote
Old 09-27-2023, 02:25 PM   #2
2019 25' Flying Cloud
Houston , Texas
The fresh water drain is a white plastic valve on the curb side behind the front wheel. Rotate the lever on the valve 180 degrees - in other words not just to align the handle with the tube, all the way.
DCPAS is offline   Reply With Quote
Old 09-27-2023, 04:22 PM   #3
2022 25' Flying Cloud
Tualatin , Oregon
We use the trailer on and off year round so we have always have fresh water in the trailer. I'm fortunate to have power available where I store it so our furnace is set to 40°. If you search the forum you'll find many that have no trouble in very cold weather as long as you use the furnace.
Steve
TitusNW is offline   Reply With Quote
Two low drain valves on fresh water tank tpmonson Plumbing - Systems & Fixtures 5 08-12-2022 07:42 AM
Fresh water tank repair and rebuild black and grey water valves Sierra Skier LP Gas, Piping, Tanks & Regulators 0 07-25-2018 11:55 AM
Fresh water tank drain for a 2014 Airstream 27fb Flying Cloud Van1 2009-2015 Flying Cloud 9 08-03-2014 12:46 PM
Fresh water drain valves amazingwoody Fresh Water Systems 8 06-14-2013 08:11 PM
Identification of Valves behind Fresh Water Drain BigGrey Plumbing - Systems & Fixtures 7 07-26-2012 06:36 AM
