Old 04-18-2024, 07:15 AM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Fresh Tank Valve & JC
I have a 2018 GT. Well it finally happened, the handle on the cheap plastic valve used to drain the fresh water tank broke. I knew it was only a matter of time. I've seen several folks have replaced it with a brass valve.
I was curious if anyone has had their valve replaced at JC (under warranty of otherwise) and what they replaced it with. And how they replaced it.
Thanks!
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
Old 04-18-2024, 07:46 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had mine replaced by the Airstream dealer in Chandler, AZ. They jacked up the trailer and cut an access hole in the tank shroud, replaced the line and the valve with an improved (??) plastic valve and put a removable cover over the access area. The labor was 2 hours...
A few years back, I had the waste tank vlave replaced in JC and they did the same process on the grey tank as the valve is hidden.
Richard
Old 04-19-2024, 05:59 AM   #3
Hans627's Avatar
I was hoping someone observed how JC replaced the valve so I could mimic the process.
BRN 22721
Fresh water tank drain valve location? trilink3 Fresh Water Systems 11 04-29-2024 08:12 AM
Cut new access & replace drain valve on fresh water tank A W Warn Fresh Water Systems 16 03-31-2022 03:10 PM
fresh water tank plug and valve repair john hd Fresh Water Systems 42 11-16-2018 12:25 PM
Fresh Water Drain Valve & petcocks dnovosad Fresh Water Systems 8 01-16-2017 06:01 PM
fresh water drain valve/open & close billiards Fresh Water Systems 7 07-22-2009 06:10 PM
