Old 05-28-2023, 04:55 PM   #1
2018 16' Sport
Fresh drain valve won't turn
New owner. First time draining 2018 Sport 16. Found the valve under the dinette seat (thanks to this forum) but cannot get it to turn. Is there a trick? Don't want to try forcing it and breaking it.
BobAtx is offline   Reply With Quote
Old 05-28-2023, 06:24 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
You might try a shot of penetratingly oil and then waiting several hours to see if it will penetrate and free up the valve. Or you might just pump your fresh water tank dry into the gray water tank and then drain the tank. You can water your shrubs with the water if you like.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 05-28-2023, 08:09 PM   #3
2019 27' Globetrotter
Missouri Valley , Iowa
My FW drain valve on my '19 27' Globetrotter was quite difficult to turn either way. Someone on the Forum suggested food grade silicone squirted up in the valve. I did that at the very end of the season. 5 months later the valve moves much easier. That silicone may work on the outside as well as the inside.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-28-2023, 08:16 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
David
I would not use penetrating oil. It might find its way into the water system. As suggested in the second post, use food grade silicone.
Also, the valve only turns 1/4 turn. Try it first one way and then the other.
Al
Old 05-28-2023, 08:39 PM   #5
2019 19' Flying Cloud
Apex , North Carolina
We will post this again because it has worked so great!!
We have a 2018 19cb. We quickly became frustrated with the black low point drain valves due to both location and poor function.
For several years now we have left the original valves open and installed these push on cpvc valves under the trailer on the 4 low point drain pipes.
Easy to reach. No more lifting mattress or crawling into storage.
Amazon
HOMEWERKS WORLDWIDE 126-8-12-12B 1/2" Push Fit CPVC Valve
Bill n Rose is offline   Reply With Quote
Old 05-29-2023, 09:03 AM   #6
2018 16' Sport
Thanks everyone! Will try the food based silicone and the push on cpvc valves.
Old 05-30-2023, 06:15 AM   #7
Boba911
2018 19' Tommy Bahama
Warwick , Rhode Island
I have a 19 ft Tommy Bahama with the same valve setup. I use a pair of pliers on the handle and turn the handle to the left so that it is in line with the pipe. Works easy that way. What I don't like, is the rat's nest of wires that are in the way that I first must move! Can't believe the sloppy wiring in these units. It looks like the total unit is hand wired each time instead of making a good fitting wire harness!
Boba911 is offline   Reply With Quote
Old 05-30-2023, 05:01 PM   #8
2018 16' Sport
South , Louisiana
Fresh water valve won't turn
It will turn.
Looking at your picture turn it to the left 1/4 turn.
Once turned a few times it will become easier.
bgum is offline   Reply With Quote
Old 05-30-2023, 05:40 PM   #9
Boxite's Avatar
2008 22' Safari
Originally Posted by bgum View Post
it will turn.
This! ^^^^^^^
Old 05-30-2023, 06:06 PM   #10
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
It's As Easy As Pie
Imagine the pointed handle is always at 12 o'clock. The handle is turned 90 degrees to 3 o'clock.
I just had mine in the off position in April to change out the toilet. I went out there just now and it was a SOB to turn.
Valves are meant to be exercised. Regularly.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 05-31-2023, 01:06 PM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I guess valves are like people; exercise regularly.
David
Old 05-31-2023, 07:46 PM   #12
1999 28' Excella
Lake Mary , Florida
try heating the valve slightly with a hair dryer, then attempt to turn.
suncoasteng is offline   Reply With Quote
Old 05-31-2023, 08:34 PM   #13
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
They do not turn easily, but they do. Suggest when you have them open save a photo for future reference.
Silvr_Bullet is offline   Reply With Quote
Fresh Water Tank Low Pressure Problems-Won't allow on demand water heater to turn on dieselsnack Fresh Water Systems 2 08-21-2018 10:02 AM
Black Tank Drain Valve Won't Close ! joanbob27 Waste Systems, Tanks & Totes 4 02-03-2016 04:10 PM
Winterizing snafu - low point drain valve on FW tank stripped and won't opem bonginator Fresh Water Systems 12 09-29-2013 02:22 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Fresh water tank in '07 won't drain - Help! ellenwall Fresh Water Systems 2 05-05-2009 06:23 PM
