Old 12-01-2024, 04:51 PM   #1
2021 30' Flying Cloud
Sioux Falls , South Dakota
Filling the fresh water tank
I thought I had asked this question before, but maybe I just thought about it.
On each of the three RV's we've owned I connected the fresh water hose to a fitting attached to a pipe that let to the fresh water tank. In looking at some Airstream videos, and reading some posts, I have the impression that Airstreams don't fill that way. I've seen people holding a hose in a fill point. Is that the normal way, or can I connect the hose to a fitting and do something else while the tank fills? We're looking at a 2012 FC 30 RBQ.
David Lininger, kb0zke
7490
2021 Flying Cloud 30 RBQ
kb0zke is offline   Reply With Quote
Old 12-01-2024, 05:07 PM   #2
NutmegsCamper's Avatar
2023 23' Flying Cloud
Another , World
Our NuCamp had the “tank fill” fitting that our hose threaded on. Our Airstream has a hole that we push the hose into, Both work the same way. Get the water flowing, and turn off the spigot when it starts overflowing. While either is filling, feel free to do something else.
NutmegsCamper is offline   Reply With Quote
Old 12-01-2024, 07:57 PM   #3
So Airstreams don't have a fitting to attach the hose? Just an open hole that you shove a hose into?
7490
Old 12-01-2024, 08:05 PM   #4
Another , World
Correct. A lot of manufacturers go this route. It’s actually a little bit simpler / quicker than threading on the hose.
Old 12-01-2024, 08:08 PM   #5
Another , World
Out of sheer curiosity, how do you have 1,421 posts on an Airstream forum and not have an Airstream?
Old 12-01-2024, 08:23 PM   #6
I have wanted an Airstream ever since I read Wally Byam's book "Trailer Travel Here and Abroad" when I was in junior high school. That was in the early 1960's. Two years ago we found a trailer in Florida that really looked good. Price was in our price range, description was what we wanted, and the pictures looked good - until the last three. Those were of young ladies in small swim suits. We couldn't figure out what those pictures had to do with selling a used trailer, so we didn't ask any more questions. When the Foretravel sold suddenly, we had to buy whatever we could at short notice, so we got this trailer. Finally, after many years of wanting and researching, we may be 10 days away from owning an Airstream.
7490
Old 12-01-2024, 09:47 PM   #7
Another , World
I love that story! The anticipation has to be Incredible!
Old 12-02-2024, 05:54 AM   #8
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
On our 19’ trailer, the fill inlet for the fresh water tank is not wide enough to insert a typical garden hose. So it has to be held in place manually while filling. But the tank is only 25 gallons or so, so it fills very quickly.
I assumed they do it this way to avoid contaminating the fresh water system by allowing a dirty hose to be inserted down into it.
At the city-water connection point we can physically screw the hose into a fitting on the side of the trailer. But there is a pressure regulator there to protect the fresh water system.
As for not having a screw fitting at the fresh water tank fill, that would seem risky to physically connect municipal water without having a pressure regulator between the hose fitting and the trailer’s fresh water system.
2017 Bambi 19 Flying Cloud
BikeCamper is offline   Reply With Quote
Old 12-02-2024, 07:20 AM   #9
2022 33' Classic
Chesapeake , Virginia
This is what I use to fill the fresh tank:
Name:	Screenshot 2024-12-02 at 08.19.38.jpg
BGClassic is offline   Reply With Quote
Old 12-02-2024, 08:28 AM   #10
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 196
RE: Potable Water Fill Fixtures & Airstream Through the Years
Greetings David!
The answer to your question is actually somewhat of it depends upon the model year of the Airstream that you are considering and whether it remains stock or if it has been modified. For instance, prior to the mid-1960s (about 1964) when the demand water system became standard, Airstream utilized a pressurized potable water system that relied upon either a cylindrical galvanized or aluminum water tank that was pressurized by filling through a city water connection that both filled and pressurized the tank using water from a hose connection on the exterior wall of the trailer -- these trailers typically had a Grover Air pressure pump to replenish the pressure as water was used from the tank (and also had a Schrader Valve for air pressure replenishment next to hose fill connection on exterior wall).
Once the demand potable water system with the PAR (Peters and Russell) water pump was adopted around 1964, the potable water tank was typically some form of plastic, and the fill fixture varied considerably from one model year to the next before the drawer-type was settled upon. Most of these early fill fixtures didn't easily accept the end of the garden hose so required some form of adapter -- the bung opening on the sidewall of my 1964 Overlander being a primary example -- it requires a slender, flexible hose of at least 8-inches for the most efficient fill, and even that will be somewhat slow going for its close to 36 gallon potable water tank. My 1978 Minuet had its original drawer type fixture for its first few years in my possession, and it was much the same as my Overlander. When that failed, my Airstream dealer suggested a more modern ABS fill fixture, and it too requires the flexible hose for ease of filling, but the tank being only about 24 gallons means that the time factor is less than on the Overlander.
I am aware of a number of members who have modified their trailer's water systems such that they can turn a valve inside of their trailer and fill their potable water tank while connected to city water. That is a bit easier to do if your tank is mounted on top of the floor where it is possible to monitor it as it fills. Where the tank is under the floor, it requires relying upon the tank monitor to relay the amount of water being added to the tank so it means one must have a high degree of trust in the monitor panel.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 12-02-2024, 09:20 AM   #11
Thanks, everyone! Lots to learn. Since we're looking at a 2021 Flying Cloud 30 RBQ, maybe someone with one of those can chime in on this discussion.
Another question: Does this trailer have an overflow pipe on the fresh water tank, or is the overflow only out the fill port? On the two trailers and one motorhome we've owned, there is an overflow pipe on the fresh water tank, so that air escapes there as water fills the tank. When the tank is completely full, water comes out of that pipe. Is that the same on this Airstream?
7490
Old 12-02-2024, 09:35 AM   #12
BikeCamper's Avatar
Hopefully you’ll hear from someone with a 30’.
On our 19’ Flying Cloud, the fresh water tank has an additional air vent to help with filling. But there is no separate overflow per se. If we overfill, it backs up and comes out the fill tube.
Old 12-02-2024, 10:05 AM   #13
Trekers's Avatar
2022 30' Flying Cloud
OKEMOS , Michigan
Our 2022 30-foot Flying Cloud has the exact same setup. -Ari
Trekers is offline   Reply With Quote
Old 12-02-2024, 11:20 AM   #14
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There is a fill point that your water goes into. Since the tank will *not* take full city water pressure, there is no thread.
There is a vent right at the intake. That vent is fed by a pretty small tube. It will allow pressure to equalize as long as you do not go to crazy.
The overflow on any / all tanks (if it exists) is out the roof of the trailer. In the case of the fresh water tank, that would be a bit of pressure. They depend on the back flow past the inlet to overflow the fill.
Since air can build up in the tank as you fill it, there can be an "eruption" if you fill to fast.
Old 12-02-2024, 12:43 PM   #15
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Dido
My drinking hose doesn't stay in the filling port very well. This little extension makes a big difference for us.
Mikebrady62 is offline   Reply With Quote
Old 12-02-2024, 12:51 PM   #16
2002 19' Bambi
Lafayette , California
There is a recent thread that might help you understand how the water fill for an Airstream works: https://www.airforums.com/forums/f44...ks-255929.html.
Your experience with filling an RV's tank while firmly connected with a hose can be arranged for an Airstream and in that same thread are a couple of contributions including this one from me: https://www.airforums.com/forums/f44...ml#post2761827.
Tim
Tim A. is offline   Reply With Quote
Old 12-02-2024, 02:49 PM   #17
2014 25' FB Flying Cloud
Cincinnati , Ohio
I just wanted to make sure you're not filling your tank with an ordinary garden hose which has unsafe chemicals. It should be a white one for drinking water.
But you probably already know this.
Our potable water hose fits in the opening of the fresh tank. I don't have to hold it there.
Outdoors4me is offline   Reply With Quote
Old 12-02-2024, 03:01 PM   #18
BikeCamper's Avatar
[QUOTE=Outdoors4me;2762572]
Yes, I am using a potable water hose. But the fittings on each end are identical size to an ordinary garden hose. These fittings don’t fit into our tank fill inlet. I wouldn’t stick them in even if they did, to avoid contaminating the fresh water system.
Old 12-02-2024, 10:14 PM   #19
Life is a Highway's Avatar
Airstream - Other
Airstream - Other
Lady Lake , Florida
We have on
PM me if you have questions or your sale goes South.
Life is a Highway is offline   Reply With Quote
Old 12-03-2024, 04:51 AM   #20
Master Chief BT
BTCMUSN's Avatar
2018 27' International
Tyler , Texas
Found this on ETSY from a vendor with 3D printer. Works very well and can just leave it connected if you want. No spill at full pressure on fill.
2018 International Signature CCD 27FBQ/Centramatics/Hensley Arrow/16” Michelin XPS RIB/TST-GM TPMS/GM Transparent Camera/Starlink STD
2024 GMC 2500 AT4 DURAMAX/Trailer Tech PKG/Centramatics/Banks Diff Cover/iDash/KATZKIN
WBCCI#11290
US Navy (ret) Master Chief Boiler Technician
BTCMUSN is offline   Reply With Quote
Filling fresh water tank 2019 airstream fresh water fill problem arvaterry Fresh Water Systems 15 07-07-2024 09:09 PM
City Water filling Fresh Water Tank and Overflowing robertwarren Plumbing - Systems & Fixtures 7 03-08-2021 09:04 AM
City water filling Fresh water tank Jkreis Fresh Water Systems 10 01-31-2021 02:29 PM
Fresh water tank filling when connected to shore water 1stredzebra Fresh Water Systems 7 12-20-2013 03:52 PM
