Anyone else experienced water intrusion into their exterior Hot/Cold Fresh Water Compartment on the side of their Airstream? (note: not referring to the "wet bay" that host the fresh water inlet (pedestal/hose) and black tank flush inlet located behind the gray/black water dump valves.
We've occasionally noted small amounts of water inside the compartment when opening it and suspect it's getting in there and collecting from rain water or condensation running down the outside of our Airstream and getting past the foam gasket AS installs on the backside of the compartment's stainless steel locking door.
We know for absolute certain that our faucet or the hot & cold water connections to it are not leaking as we changed it out awhile back and made certain of positive connections. Now, an only suspect that its the foam gasket on the compartment door not sealing properly and letting water in from the outside.
Curious if others have encountered this and if so, what their solution was?
