04-26-2025, 02:45 PM
3D printing guy
2023 23' International
Overland Park
, Kansas
Experience with Camco EvoFlex2 50-ft Drinking Water Hose
Just tried this out at a campground that had very good water pressure. It had a small leak where the hose begins at the female end (not the washer). When I return it should I just get a replacement and assume that this is a one off situation? Or, is this a product that I shouldn't buy again?
WBCCI 6561
04-26-2025, 04:07 PM
2022 33' Classic
Chesapeake
, Virginia
While this may not help, I use the Camco TastePURE variety, and have not had any failures. Some of mine are four years old. I also have the coil-type RV water hose offered by Air Gear, which has held up.
04-26-2025, 06:46 PM
2019 22' Sport
High River
, Alberta
Unless you’re close to the store where you bought it and can get a warranty replacement, I would buy a new end and a stainless steel hose clamp.
04-26-2025, 09:32 PM
1994 25' Excella
Waukesha
, Wisconsin
I've used the FileZilla hoses for a while now and find that they are much more flexible and user-friendly. They are drinking water safe/approved. These are the bright neon green hoses.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
04-27-2025, 06:20 AM
3D printing guy
Overland Park
, Kansas
Flexzilla
WBCCI 6561
04-27-2025, 10:21 AM
1994 25' Excella
Waukesha
, Wisconsin
Originally Posted by englewoodfl
If you look at that Home Depot description it does say on there "drinking water safe" referring to the lining inside the hose.
The flexibility of these hoses is a game changer.
Here's the same information from their website itself:
Richard
11018
04-28-2025, 06:48 AM
1988 29' Excella
Lorena
Zero-G
I’ve been using the Zero-G RV and marine hose for several years. It takes less space and works well for me.
https://www.acehardware.com/departments/lawn-and-garden/watering-and-irrigation/garden-hoses/7039641
04-28-2025, 08:15 AM
Tampa
I've been using the Zero-G hose for years. Stores easily.
I wish they made a 10' version.
BTW, the only difference between the Zero-G and the Zero-G RV & Marine is the color. All are drinking water safe.
05-12-2025, 03:48 PM
FL_Jim
2023 30' Flying Cloud
COCOA BEACH
I've tried the Zero-G and had the same leaking problem on the female end that englewoodfl describes.
Must just be "Luck of the draw"...
I've found it hard to find a drinking water that will not start to leak after a few uses.
05-12-2025, 04:10 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
Another vote for the Zero-G hose. I recently ordered a second 25 footer and noted that the fittings have changed from aluminum to brass (or something brass colored).
05-13-2025, 07:38 AM
3D printing guy
Overland Park
, Kansas
Flexzilla
I decided on Flexzilla - no leaks and it can handle the high water pressure here in Overland Park. After some testing decided to buy a 50 footer for the hose - very happy with it.
WBCCI 6561
