10-04-2020, 02:01 PM
#41
2019 27' Globetrotter
2023 30' Classic
Denver
, North Carolina
Another Zero G user. I drain the hose and connect the ends at the end of the season. More importantly come spring I run a diluted bleach solution thru it, the same solution I fill my fresh water tank with and then run it thru all the plumbing.
Dave S
10-04-2020, 03:13 PM
#42
Dillsburg
, Pennsylvania
We’re working on six years with our Zero-G. One of the best RV accessories we’ve ever bought. Weighs almost nothing, and you can just stuff it away in a small compartment with the ends screwed together.
John in PA
Originally Posted by rucos
I use standard white RV hose....drain after use...screw ends together ....and keep in storage box. Very interested in the Zero-G that several have mentioned here...always learning something new!....LOL
10-04-2020, 04:26 PM
#43
2015 Interstate Ext. Coach
Mesa
I’m a roll it up, screw the ends together, amd throw it where it will fit. If it springs a leak I replace it. I’ve been at it over 60 years and caught nothing yet from my water hose.
10-04-2020, 06:54 PM
#44
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Originally Posted by cantdrv55
please post a pic of the shelf, if you wouldn’t mind. Thanks!
10-04-2020, 08:15 PM
#45
1976 Argosy 26
Lake Wales
All hoses get mold in them no matter what you do. The white ones are no different. Use a filter.
10-05-2020, 07:17 AM
#46
2005 22' International CCD
Pittsburgh
, Pennsylvania
Hose Cleaning
Occasionally during the season and at season's end I sanitize the white water tank. I drain solution thru the supply hoses, hang them up on a 'hose tree' I made from a 10' PVC pipe and let air dry. I either screw ends together or attach caps.
10-05-2020, 07:42 AM
#47
1967 17' Caravel
Austin
I drain the hose while rolling up and place in interior storage compartment. I do not screw the ends together as I do not want to create a terrarium environment inside the hose. I filter and flush before using.
10-05-2020, 09:34 AM
#48
Tampa
Originally Posted by DCPAS
Sorry for the thread drift, but could you please add a link for the quick release fittings?
Originally, I used QuikLink, but they discontinued the angled fitting that's perfect on the Airstream. So I found Gorilla connectors, built like tank, but backwards to most mechanics, never leak.
https://www.rvh2o.com/category/kwiklink.html
The right angle connector might work, Since I have the angled, I just leave it on the trailer, it has a cap.
https://www.amazon.com/GORILLA-EASY-...49&sr=8-1&th=1
10-05-2020, 11:12 AM
#49
benicia
Thanks for taking the pic. Ingenious.
10-05-2020, 11:13 AM
#50
benicia
Originally Posted by sheriff1
Thanks! Great idea
10-06-2020, 09:18 AM
#51
2019 22' Sport
Bend
, Oregon
Not sure how problematic trace amounts of mold are to 99.99% of the population. Lots of mold in the world.
I doubt you're going to grow much mold on residual potable water.
