Old 09-30-2018, 10:38 AM   #1
Dickandvicki's Avatar
1991 29' Excella
Tulsa , Oklahoma
Does Shore water go thru water pump?
I posted an earlier thread about my fresh water being discolored. It comes out sort of grey when the tap is just opened then clears quickly. We have thoroughly sanitized our tank and lines. We have flushed our lines multipal times. And still we are having discolored water. There is no noticeable odor.
We are going crazy. I just donít see where this could be coming from. The water looks like a charcoal filter has come apart and is getting into our lines. We have looked at all the lines from where the water hooks up to shore (under the twin bed), the plumbing in the wardrobe and under the sink. It all looks fine, though we havenít disconnected anything..yet.
My question is since we are having this problem when using water from the tank and when using shore connection. Is it possible this could be coming from the pump?
Iím going to try to attach a picture.
Any help would be greatly appreciated.. Thank you
Dickandvicki is offline   Reply With Quote
Old 09-30-2018, 10:57 AM   #2
Long Island , New York
Please see my reply in your old thread, so that folks have some continuity about the history of your problem, with all considerations located "on the same page."
http://www.airforums.com/forums/f443...er-186157.html
Please reply in that thread with more details.
Peter
Dometic refrigerator wonít run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 22 04-10-2018 02:57 PM
shore power and water pump question dcorona Water Heaters, Filters & Pumps 3 05-26-2015 10:17 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
trying to remove - does bathtub section fit thru door groovzilla Sinks, Showers & Toilets 4 11-16-2013 05:23 AM
2010 Int'l: Does cable coax go straight thru? or thru amp? amm3824 Audio, Video & TV 2 10-18-2010 08:32 PM
