Old 08-03-2020, 12:33 PM   #1
1976 31' Sovereign
Detroit , Michigan
Exclamation Cracked Copper-to-"Pex" Coupling
Hi there AS'ers!
JUST brought our new pride & joy "Pearl" home = 1976 Sovereign LY 31"
Maiden voyage we flicked on the water pump from our freshly filled water tank and water started pouring out of the roadside of the frame.
Found this on the floor in our closet where the water pump send it's copper line up through the floor.
I just need some help on which "Brand" or standard of coupling this is. I don't think its official "Pex" or SharkBite but I'm not sure.
Any of you vets know what terms I should be hunting to find my replacement?
Any other pointers for this obvious tight/complex Copper/Floorboard juncture? Should I go further up-stream with Pex to the water pump if possible to avoid this problem area going forward into the future?
GoingRemote is offline   Reply With Quote
Old 08-03-2020, 08:41 PM   #2
2008 27' Safari FB SE
Miami , Florida
You need a brass SharkBite 90deg 1/2 x 1/2 (measure, though, could be 3/8”) should be labeled fro bot PEX and copper.
Middle-aged (usually dirty) Nissan Titan XD
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Goofy dog
Old 08-04-2020, 12:04 PM   #3
1976 31' Sovereign
Detroit , Michigan
Ok. SharkBite branded. Wanted to make sure I was on the right track. Thanks!
What is best PEX coupling for water pump? Bexar Water Heaters, Filters & Pumps 13 03-28-2018 06:32 PM
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
Keep the copper or replace with PEX kdenault Fresh Water Systems 16 03-13-2007 09:37 PM
Cost: PEX vs Copper TomW Fresh Water Systems 5 04-13-2006 06:15 AM
