Old 09-07-2017, 10:36 AM   #1
coolbabe's Avatar
1976 Argosy 26
Lake wales , Florida
Clean fresh water tank
I need to clean my freshwater tank as it has sat empty for at least a year. How do I do that?
coolbabe is offline   Reply With Quote
Old 09-07-2017, 11:05 AM   #2
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Sanitize the Tank with bleach
From my 2008 Owners Manual
SANITIZING
Potable water systems require periodic maintenance to deliver a consistent flow of fresh water. Depending on use and the environment the system is subject to, sanitizing is recommended prior to storing and before using the water system after a period of storage. Systems with new components, or ones that have been subjected to contamination, should also be disinfected as follows:
1. Use one of the following methods to determine the amount of common household bleach needed to sanitize the tank.
A) Multiply “gallons of tank capacity” by 0.13; the result is the ounces of bleach needed to sanitize the tank.
B) Multiply “Liters of tank capacity” by 1.0; the result is the milliliters of
2. Mix into solution the proper amount of bleach within a container of water.
3. Pour the solution (water/bleach) into the tank and fill the tank with potable water.
4. Open all faucets (Hot & Cold) allowing the water to run until the distinct odor of chlorine is detected.
5. The standard solution must have four (4) hours of contact time to disinfect completely. If you double the solution, this concentration allows for contact time of one (1) hour.
6. When the contact time is completed, drain the tank. Refill with potable water and purge the plumbing of all sanitizing solution.
NOTE: The sanitizing procedure outlined above is in conformance with the approved
procedures of RVIA ANSI Al19.2 and the U.S. Public Health Service.
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 09-07-2017, 11:14 AM   #3
1979 23' Safari
Wayland , New York
1/2 teaspoon regular Clorox bleach per 10 gallons capacity of the tank (splashless or scented bleach cant be used, generic regular bleach is ok). Mix the bleach first with a little water then pour into the tank inlet. Then fil the tank, this helps ensure a good mixing. Run the fresh water pump to get some bleach in the pump. Let sit for at least 30 minutes, an hour is better. You can use a little more bleach but don't go overboard. Drain tank. Repeat if you're really worried. Refill tank with fresh water and use pump to run water through faucet to rinse out pump and tank of bleach residue. I would refill it one more time for a final rinse. Then use it.
Old 01-16-2019, 06:57 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Interesting blog on conserving water. Just ordered a Danco water-saving aerator for the bathroom. We boon-dock a lot around Colorado during the summer. Thanks for posting your ideas/practices!
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 01-16-2019, 07:25 PM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
BTW, we made a change to our toilet plumbing which inserted a "T" before the toilet valve which connects to a hand-held sprayer. That way, we can use the sprayer without flushing the toilet at the same time. Allows us to clean the toilet up before flushing thus conserving water.
DaveP
2023 Ram 3500 4x4
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 31 05-15-2022 10:25 PM
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 26 04-24-2021 05:23 AM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 07:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Need to clean fresh water tank? tcrum Fresh Water Systems 4 04-07-2010 09:25 AM
