Old 04-03-2019, 01:08 PM   #1
my3sonsdad's Avatar
Vienna , VIRGINIA
City water leak
Could use some help.
Any reason why these connections would be plumbed this way coming in from the city water? The height of the 2 90* turns are slightly different so maybe they used some flex piping to compensate and never got back to correcting it.
Currently leaking at the grey adapter Click image for larger version
2001 Ford Excursion 7.3L
my3sonsdad is offline   Reply With Quote
Old 04-03-2019, 05:41 PM   #2
Paradise , Texas
It appears as that was a crappy patch job.... There may have been a regulator that was present in the past, and it is missing.
In all honesty, you are better off replumbing with pex.
Crackerman is offline   Reply With Quote
Old 04-03-2019, 06:54 PM   #3
2019 30' International
Pennsylvania , Pennsylvania
That looks like a Rube Goldberg job.
Fix it as it is or go with less parts to make the connection.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 04-03-2019, 08:58 PM   #4
my3sonsdad's Avatar
Vienna , VIRGINIA
City water leak
Would you believe that was a professional job? I find the RV center’s stickers everywhere. All the remaining plumbing appears to be some type of pvc. These appears to be the remnants of the original factory plumbing that was “modified”.
I’m going to add an interior water filter system here since I have to take it apart to temporarily repair.
Old 04-04-2019, 09:48 AM   #5
my3sonsdad's Avatar
Vienna , VIRGINIA
I’m planning to replace/remove this section altogether. Is the circled piping some type of pressure release?
I’m planning to install an new shurflo water entry which already has a pressure regulator & check valve, so I think I can do away with this altogether.
Thoughts?
Old 04-05-2019, 09:47 PM   #6
SlvrTwinkie's Avatar
1976 29' Ambassador
Logansport , Indiana
Looks to me, the spot you circled is where your FW system ties into the rest of the water system. As for the "fix" I agree it looks as if someone took out the pressure regulator for the city side and did a very lousy job doing it. Now dealing with a leak at the grey coupler, you can either see if you can tighten it to stop leaking or just replace it with a new one. Should be able to find that coupler at just about any hardware store in the plumbing department.
SlvrTwinkie is offline   Reply With Quote
Old 04-05-2019, 11:12 PM   #7
my3sonsdad's Avatar
Vienna , VIRGINIA
I took both sections apart.
The brass coupling on the left was a pressure regulator. The red circled pipe was a pressure relief value. I’m removing the whole section and installing a new Shurflo water entry that has both a pressure regulator (65 psi) and a check valve. The city water bib is currently on the bumper...not convenient at all. The shurflo will be located near about 6-8” above the bumper. I’m going to redo the lines with pex.
Water leak when hooked up to city water. Please help :) jck_dmb General Repair Forum 29 11-24-2020 09:17 PM
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Leak in belly, by city water inlet...HELP rfield54 Fresh Water Systems 26 05-31-2010 06:20 PM
Leak Under City Water Connection JDL Fresh Water Systems 8 08-14-2006 01:16 PM
