Old 10-30-2019, 04:25 PM   #1
2015 27' Flying Cloud
Currently traveling , Varies
City water inlet leak under pump?
We have had a slow leak develop and I believe it is from the city water inlet (insulation wet around there). I am only using my tank and pump now due to the nighttime temps getting into twenties and teens. The pump will pulse several times during the night (when cold), which got me looking. I keep hot water heater on at night with furnace to prevent freezing. Could this inlet be causing problem when on internal tank and pump? I have tried to trace lines and think so, but not sure (canít find plumbing diagram).
I have tried tightening 4 screws on back of regulator/inlet, but not sure that has done it. Anyone know if a replacement can be ordered on Amazon or at camping store if itís the culprit (full timing)? My guess is that water in regulator may be freezing and causing issue at night?
Thanks in advance!
Jared Jamison
www.astreamcometrue.com
Instagram @astreamcometrue
SabaRocks is offline   Reply With Quote
Old 10-30-2019, 04:47 PM   #2
I think this is the replacement on Amazon.
SHURFLO 183-029-14 Pressure Reducing City Water Entry (Wall Mount) -Chrome
https://www.amazon.com/dp/B002OUPFOU..._waHUDbKGXQ0YQ
Jared Jamison
Old 10-30-2019, 05:26 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Yep, that looks like it.
Same part from ODM>
http://odmrv.com/catalog/index.php?m...roducts_id=902
Alan
Old 10-30-2019, 10:00 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
When mine went bad, it did also leak when we were using the fresh tank & pump. To complete the trip we were on, I cut & plugged the PEX that connects to it.
And this is a case where insulation is not your friend. If insulation is packed around the fixture, that prevents the heat inside the trailer from reaching it. When I was in there, I pulled out some insulation (just from the immediate area).
I now have a water detection alarm on the floor under this area, to alert me next time.
SSquared is offline   Reply With Quote
Old 10-31-2019, 09:00 AM   #5
Thanks for the verification that my issue could be regulator. Good idea on the temp fix. Makes me think I should install a valve inline on the PEX to be able to shut it off when not in use (which will likely be always). Have a new regulator on order to replace at next stop.
Jared Jamison
Old 10-31-2019, 09:15 AM   #6
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
The water inlet is a cheap (unless you have to buy a new one) plastic assembly and is often a cause for failure and water damage to the subfloor. Our first trailer cost us almost $10K to repair because we never noticed any symptoms until too late. Part of the problem is the way some connect the hose and filter causing a strain on the plastic assembly. I always put the filter next to the water supply hose bib and use a bungee cord connected to the side awning hook to reduce strain. I inspect often and I'm on my 3rd replacement inn 10 years (two trailers).
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
hhendrix is offline   Reply With Quote
Old 10-31-2019, 09:26 AM   #7
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Yup, like everyone said. I had mine replaced under warranty.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
City water inlet and potable water inlet replacement sizing? LiamO86 Sprinter and B-van Forum 2 05-09-2019 05:05 PM
Water leak at city water inlet, not hose connnector EddyBearPS Plumbing - Systems & Fixtures 12 05-01-2019 06:58 AM
Leak in belly, by city water inlet...HELP rfield54 Fresh Water Systems 26 05-31-2010 06:20 PM
City Inlet Water Leak Into Tank Two Wise Ones Fresh Water Systems 11 04-06-2008 04:51 AM
