Old 01-29-2021, 03:30 PM   #1
2019 28' International
Murphy , Texas
City water filling Fresh water tank
I have 2019 28 international rear bed queen. I just noticed water draining from the fresh water tank. Iím hooked up only to city water. ??
Jkreis is offline   Reply With Quote
Old 01-29-2021, 04:29 PM   #2
1986 31' Sovereign
Miami , Florida
There is a check valve built into your fresh water pump that is supposed to prevent this. It is not unknown for the valve to stick or a small piece of debris to cause it to leak.
First aid is to shut off your city water and use your pump and your onboard tank. Sometimes this alone will fix it. Sometimes a new pump may be in order...
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 01-29-2021, 04:48 PM   #3
Sag Harbor , New York
Ditto.
https://www.google.com/search?q=Pump...=airforums.com
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 01-29-2021, 05:14 PM   #4
2019 30' Flying Cloud
Grass Lake , Michigan
Same thing happened to us last summer. We installed an additional check valve between the pump and the tank to prevent recurrence. There are several threads on this topic, so it seems to be a common problem.
oldenavy is offline   Reply With Quote
Old 01-29-2021, 05:57 PM   #5
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
Had same issue on our AS's first trip when new in 2018. Running off the pump to run tank down corrected the issue for two years. Last fall it started again intermittently, so I replaced just the check valve in the pump. Check valve part number is listed in the water pump manual.
StuartsDad is offline   Reply With Quote
Old 01-30-2021, 06:17 AM   #6
Baby Zeppelin's Avatar
Clayton , Georgia
I removed my water pump a couple of weeks ago, took it apart, and cleaned the valves. All looked fine. Had hoped to find a pine needle or other debris there. Put it all back together and installed an extra check valve as a precaution.
Then tested the pump by pumping antifreeze through the system.
Will have to wait until the next camping trip to see if the overflowing fresh water tank issue is resolved.
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 01-30-2021, 09:59 AM   #7
1996 25' Excella
Tillsonburg , Ontario
You do not have to replace the whole pump. I have installed a repair kit on my pumps twice. Once it was found not necessary. It was a faulty suction connection.
Start with running the pump with city water turned off to try to clear the check valve, then if necessary replace the check valve
JCW
JCWDCW is offline   Reply With Quote
Old 01-30-2021, 10:12 AM   #8
2019 25' International
Washington , Washington, D.C.
Where does the fresh water drain from? From behind the little locked door where the lid screws on to the water inlet?
PatLee is offline   Reply With Quote
Old 01-30-2021, 12:10 PM   #9
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
I kept having this problem, got ready to replace pump after rebuilding it a time or two, then put this in, very easy and haven’t had any issues since.
SharkBite U2008-0000LFA 1/2 inch x 1/2 inch Brass Check Valve, Push-to-Connect, Copper, PEX, CPVC
by Amazon.com
Learn more: https://www.amazon.com/dp/B00506ET10...ing=UTF8&psc=1
Growing old should have taken longer
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 01-30-2021, 12:58 PM   #10
A quick short-term fix is to shut off the hose feeding the city water [with pump off], and open a faucet until there is no water flow from the faucet.
Close the faucet, and turn the pump on and off quickly a bunch of times [5 or so], until the system reaches full pressure.
This will often clear out any grit from the pump. Hook back up to city water and see if the problem has gone away.
Always use an inline RV water filter in your potable water hose, both for filling the tank, and for supplying city water.
PS -- The search results in Post #3 lead to lots of discussions about this.
Good luck,
Old 01-31-2021, 01:29 PM   #11
Originally Posted by Jkreis View Post
I have 2019 28 international rear bed queen. I just noticed water draining from the fresh water tank. I’m hooked up only to city water. ??
Wondering if you tried any of the suggestions here?
Happy trails,
Fresh water tank filling when hooked to city H2O. OffTheCouch Plumbing - Systems & Fixtures 13 03-18-2019 06:34 AM
Grey water tank filling from city water bearded19711 Plumbing - Systems & Fixtures 22 03-17-2019 04:23 AM
City Water filling my tank. Milly Fresh Water Systems 16 01-11-2019 10:28 AM
city water hookup filling fresh tank? joevdb Plumbing - Systems & Fixtures 20 06-27-2017 06:17 PM
Fresh water tank filling when connected to shore water 1stredzebra Fresh Water Systems 7 12-20-2013 02:52 PM
