Old 03-01-2022, 08:13 AM   #1
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
choosing fitting for repair
Discovered a water leak above hot water heater at a T connection. Very limited space is going to require a use of a Shark Bite style connector, which Home Depot shows they carry. Don't see any other method of making the repair, don't have room for a crimping tool. Looks like I'm off to Home Depot, need to get my water going again. If any suggestions or advice on the repair/choice let me know, kinda stuck for options
Name:	All Photos - 1 of 1.jpeg
rbs is offline   Reply With Quote
Old 03-01-2022, 10:36 AM   #2
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
I haven't used the Shark Bite fittings on my AS yet, but they work well on the pex tubing on my house. That's what I would use.
JEWare
John Ware is offline   Reply With Quote
Old 03-01-2022, 10:51 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If you use the Shark Bite fittings you'll have to make sure you clean all the crud off those pipes, and also make sure that there are no defects/deep scratches/etc or you may not get a good seal. Those fittings rely on an O-ring to make the seal, and if that O-ring hits a damaged part of the pipe it will leak.
Possibly it would be worth a try with a brass barbed fitting and some good quality hose clamps.
Richard
11018
richard5933 is offline   Reply With Quote
Fresh water tank fitting-cracked-repair? retirenow Fresh Water Systems 24 06-28-2020 07:20 PM
Water heater tank hole repair at fitting: weld? rippie Water Heaters, Filters & Pumps 5 01-29-2014 05:02 PM
Need Help Choosing Trailer Please! tallone Member Introductions 22 01-23-2006 09:54 PM
discovery,globetrotter choosing an outfit wilson russe Tow Vehicles 1 10-03-2004 11:18 AM
Choosing the Right Model Airstream MH grassgd Airstream Motorhome Forums 13 01-06-2003 10:59 PM
