Old 01-24-2025, 03:18 PM   #1
Rae
Airstream - Other
Devine , Texas
Bypass pressure Valve?
My hose attache's to the pressure valve(?) The fitting that the hose attaches to broke off. Can I take the pressure valve off and run the hose to the pipe?
Rae is offline   Reply With Quote
Old 01-24-2025, 08:57 PM   #2
1988 32' Excella
Robbinsville , New Jersey
You mean the city water inlet, this.
https://www.amazon.com/SHURFLO-183-0...s%2C158&sr=8-1
If it still works as an anti-back flow valve (doesn't have water coming out while using the pump) the easiest thing would be fill the tank and use the pump. Otherwise just get a new one (should be available at most RV dealers and supply places) and replace it.
Would help to know year and model of trailer to know if it has that inlet.
Old 01-25-2025, 04:53 AM   #3
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
If you have to replace the whole thing Airkrafters now makes one in stainless steel, not cheap but all their stuff is great.
Keys Dave is offline   Reply With Quote
Old 01-25-2025, 05:32 PM   #4
Rae
Airstream - Other
Devine , Texas
Thank you so much Wazbro! I think you gave me what I needed. My rv is a 66 holiday rambler, do you think the inlet you sent a link to will fit it or am I going to have to get one for my rv specific? I'm a pretty handy girl but this is out of my scope.
Old 01-25-2025, 05:34 PM   #5
Rae
Airstream - Other
Devine , Texas
I'm hoping Wazbo fix will work, it's only 50 bucks! But if not I'll check them out for sure!
Old 01-25-2025, 05:39 PM   #6
Rae
Airstream - Other
Devine , Texas
I just look at the inlet and I have a metal pipe at 3/4 to one inch that thr old pressure valve attaches to. The inlet in the link is a tiny plastic thingy... any suggestions?
Old 01-25-2025, 08:21 PM   #7
1988 32' Excella
Unfortunately an older trailer would have a different setup then that, Airstream didn't start using those until the 90s', most others probably started around the same time. This why info about the trailer helps.
Some pictures might give someone a better idea of what you need for repairs.
Old 01-26-2025, 08:07 AM   #8
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
Post a picture of the item that you are having trouble with. A trailer that is almost 60 years old can have several modifications by previous owners, and most of us on this site are familiar with Airstream/Argosy systems. We are more than willing to help, but "thingy" is not a description of an item that I am familiar with. A picture is worth a thousand words! Are we talking water or propane?
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
AC High/Low pressure switch bypass Vycan Classic Motorhomes 1 01-12-2015 04:32 PM
Water heater bypass valve Robfike General Motorhome Topics 6 05-11-2014 06:21 PM
Int'l 23D HW tank bypass valve location? DreamsInSlvr 2011 - 2015 International 2 09-17-2013 05:08 PM
Bypass Valve tomb Water Heaters, Filters & Pumps 0 11-26-2002 06:42 AM
