Old 11-27-2018, 06:57 PM   #1
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Alright... new issue...
Did a search, couldn’t find anything.
At a full hookup sight. Hooked up as normal. Had an empty fresh water tank because I knew we were going to be on city water.
Wife commented that tank was full. Didn’t think anything of it. When I went outside to drain tanks there was water coming out from the fresh water fill port and from what I believe is the tank directly.
I turned off the city water and am on pump now. Everything seems to be working but I think I am hearing water draining into the tank now or running through pipes. Don’t ever recall hearing this before, could I have a busted pipe somewhere that is causing both issues?
Never had the city water fill my fresh tank before, thoughts?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 11-27-2018, 07:02 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Somewhat of a common problem.
Here’s an old thread that has links to other threads where this has been discussed before. Could be a pump/check valve problem. See if any of this helps and good luck!
http://www.airforums.com/forums/f163...nk-167100.html
Old 11-27-2018, 07:17 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Pump check valve is leaking allowing water to flow back into the tank.
Old 11-27-2018, 07:22 PM   #4
2018 30' Classic
Thanks. I turned off city water and am running off pump. Hope that clears any debris keeping valve open. Pump is loud like reported in other threads, but once I run this water down I’ll turn the city water on again and will see if fresh tank fills again.
Already planning a trip to Jackson center in spring time. Adding this to the list. Hope no other issues with our water system exists... I feel like I am hyper sensitive to water dripping and draining sounds now because I feel like something is broken 🥴
BigSxyWhtGuy
Old 11-27-2018, 08:10 PM   #5
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I installed a new Shurflo 4008 Revolution pump in my trailer last year. Recently I discovered the same issue. I purchased the check valve replacement kit, about $14 to $17. Seemed to have fixed the issue after one day of testing. I believe the same pump is used in newer Airstreams.
When I disassembled the check valve I didn't see anything that would of caused the issue; no debris or hard water deposits. Easy to replace and worth a try before buying a new pump.
Kelvin
Old 11-28-2018, 04:40 AM   #6
Sag Harbor , New York
Did you use the new search function in the blue box above? It works great.
The old search function in the blue menu bar never worked well IMO.
“Water fill overflow” — https://www.google.com/search?q=Wate...=airforums.com
Your plan in Post #4 should do the trick IMO. Do you use an inline water filter in the hose for both filling the tank and city water?
https://www.amazon.com/Camco-TastePU.../dp/B0006IX87S
Using this religiously should prevent a reoccurrence.
FYI
FWIW
Old 11-28-2018, 05:57 AM   #7
2018 30' Classic
Yes, I have a water filter. I don’t use for filling fresh tank but will now. Have traditionally used only for city water connection but I guess if I am filling fresh before disconnecting from sit then it is filling with filter. Only a couple times have I filled fresh randomly and not used filter.
Been on road for 8 months. Airstream still under warranty. Pump should be covered.
BigSxyWhtGuy
Old 11-28-2018, 11:01 AM   #8
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi BigSxyWhtGuy,
We know you already have an appointment at Jackson Center, but if there is anything that we can assist with now, please do not hesitate to reach out.
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Electrical issue with new flying cloud fishon General Repair Forum 8 10-28-2013 08:00 AM
Electrical issue with new flying cloud fishon Member Introductions 0 10-27-2013 08:57 AM
Any issue with putting new floor over existing linoleum? mikeandnora Floor Finishes 7 04-04-2012 09:51 PM
New lights and the 12V issue soldiermedic Electrical - Systems, Generators, Batteries & Solar 8 10-30-2006 06:33 PM
