Old 10-21-2018, 10:37 AM   #1
RichHog's Avatar
1972 23' Safari
Houston , Texas
72 Safari Fresh Water Drain
So I'm still trouble shooting the water system on this trailer. Tried filling up the fresh water tank and noticed water coming out of a plastic tuber poking out of the belly pan under the tank. Further inside inspection shows a water outlet from the tank that has a T on it with one side going down to the drain tube and the other side going into the water pump. from what I can tell there is no water valve in this run to stop the water from draining out and sending it only to the water pump. Any thoughts on this or what not should do?
RichHog is offline   Reply With Quote
Old 10-21-2018, 01:36 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It sounds like the water tank drain valve is open. There should be a valve under the floor and accessible under the sink area. That is how my 75 Trade Wind was built.
Richard
Old 10-22-2018, 09:52 PM   #3
RichHog's Avatar
1972 23' Safari
Houston , Texas
There isn’t a valve and am wondering if a PO removed it and replaced with a T connection to let it drain out the bottom. Perhaps a freeze protection move.
Old 10-27-2018, 08:35 AM   #4
RichHog's Avatar
1972 23' Safari
Houston , Texas
Fresh Water Tank Plumbing 72 Safari
So there is a T that comes up from the fresh water tank and has a drain hose that goes out the belly pan to the ground then the other side goes into the water pump. When I was filling the tank the water just goes out of the drain and not to the pump. Shouldn't there be valves on this? One to stop water from going to the drain line and another to stop water going to the pump so that it is forced to drain the tank. I can not find any other valves under the sink or flooring.
ID:	326405   Click image for larger version
Old 11-06-2018, 09:13 PM   #5
RichHog's Avatar
1972 23' Safari
Houston , Texas
Between the grey connectors is the T that goes to the drain without any valve. Anybody got any thoughts on this?
Fresh Water Drain for 1965 Safari MittenKitten Fresh Water Systems 1 02-08-2015 02:10 PM
Replacing Fresh Water Drain Petcock on 99 Safari Clawdan Fresh Water Systems 10 01-14-2010 04:15 PM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
