Old 10-06-2020, 02:56 PM   #1
Lil Bear's Avatar
2019 30' Classic
Cary , North Carolina
ZipDee Relax Awning -2019 30 Classic
I was having an issue with the power awning to close all the way. After pushing the retract button at the door panel a few times I was able to walk the awning back in the last foot or so.
I then tried to extend the awning and nothing...
I called Zip Dee and tech support determined that the awning components were fine, but the AirStream controller was bad.
I called AS Tech Support. After a couple of power downs, battery disconnects, and updating the AS App...still nothing. The support person said I should take it to the dealer to have a tech with a multi-meter check out the system. Our nearest AS dealer is 90 miles away.
I went to my trusty Air Forums and did a search and found some conversation around the circuit board behind the bottom drawer in the galley, and advice to check wire connections. There was one mention of a reset switch. Bingo! I checked the wire connections, made sure there was not water intrusion/damage (since the board sits right below the sink). I powered up the 12V battery connect (leaving off shore power) and pressed the little black reset switch. I flurry of flickering green lights on the board told me I was on to something! The awning now works as it should from the panel at the door, and the AS Smart App!
Here is a picture of the circuit board enclosure and the black reset button can be seen on the left just below the orange wire.
If you are having issues try this first!
Lil Bear is offline   Reply With Quote
Old 10-06-2020, 05:11 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Nice job
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Who has a Zip Dee Relax 12v Automatic Awning? veg hed Awnings 54 03-16-2021 05:18 PM
ZipDee Relax and a maintenance tip turk123 General Repair Forum 0 06-03-2019 07:26 PM
Replace perfect ZipDee awning with power awning? Barretta2 Awnings 23 07-03-2017 05:45 AM
Wind sensor available for the ZipDee Relax Awning alano 2016 - Current Classic (all lengths) 11 04-29-2016 04:36 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
