Old 02-24-2017, 09:51 AM   #1
2002 25' Safari
Eugene , Oregon
Zipdee Awning won't come out
Hi All,
My ZipDee awning on my used 1994 Airstream won't come out. I know it functions as the previous owner took lots of pictures and had it out all the time. It was a warm day so I thought I'd pull it out.
I undid both screw wheels on the side. Grabbed the awning bar and pulled. It raised up and didn't come out. I pulled so hard the fabric loop BROKE!
Any ideas or anything that should be lubricated maybe to make it come out?
Thanks in advance
clarity6406 is offline   Reply With Quote
Old 02-24-2017, 09:57 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Some rollers are locked with an lever at the end of the mechanism. There may also be a travel lock between the metal casing and the coach body but you should have seen that. May also help to take the rafter arms loose from the stowed position pin on the lower main awning arm.
Old 02-24-2017, 10:09 AM   #3
2002 25' Safari
Eugene , Oregon
Thanks! I removed the arms too to see if that helped and it still wouldn't budge
Old 02-24-2017, 11:32 AM   #4
Mollysdad's Avatar
There has to be a lock, otherwise wind gets under the roller and unfurls it while you're driving.
On mine (not an AS) on the front of the roll is a flip lever I have to pull down with the rod. Then I can engage the pull loop and unfurl the awning.
I have seen aftermarket locks for folks that want extra security like Kansas during their high winds.
Old 02-24-2017, 11:35 AM   #5
2002 25' Safari
Eugene , Oregon
I had a 25' with the lock, which I'm familiar with. I've looked all over and cannot find one. Guess I'll look even harder.
Old 02-25-2017, 12:30 PM   #6
OttawaValleyGuy's Avatar
1991 35' Airstream 350
Beachburg , Ontario
Call me at 386 984 1340
I can walk you thru the process it is NOT difficult
You need a drill a 5/32 bit and a vice grip
That is it
Howard and Ann Schutt
OttawaValleyGuy is offline   Reply With Quote
Old 02-25-2017, 01:07 PM   #7
1982 27' Excella
Huntsville , Texas
Zepded Awning
When I got my used 1982 model I had a very hard time getting the awning to open. A lot of penetrating oil, WD40 time and effort and it finally comes open.
GMarugg is offline   Reply With Quote
Old 02-26-2017, 07:04 AM   #8
Beachburg , Ontario
Did you get my phone number ?
I can tell you exactly how simple it is to get your zip dee awning to open
Old 02-27-2017, 11:48 AM   #9
Mollysdad's Avatar
Is yours like this?
Old 02-27-2017, 12:56 PM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
On mine the little short shaft on the forward end, where on mine there is a lock, was frozen in the bearing. no way to get to it without taking the end out of the awning. I ordered a new end from Zip Dee, installed it, and now the awning works fine.
I actually had to undo the screw that holds the shaft into the curved awning arm to unroll the awning to change the end piece. 2 man job to get it open that way.
slideout won't come out. Clyde Gartman General Repair Forum 13 09-30-2016 06:53 PM
Open House!!! Come one come all!!! wheel interested Photography 248 08-21-2012 08:32 AM
21" zipdee won't loosen to unroll sharptalk Awnings 17 10-04-2009 11:08 AM
chat, come one come all! john hd Off Topic Forum 13 01-25-2005 06:51 PM
