Old 08-11-2019, 03:46 PM   #1
1990 29' Excella
baltimore , Maryland
Zip Dee to Airstream body needs tightened...
So on my 1991 Excella, the middle pole, where it attaches to the airstream body, is loose.
The bracket is connected to the airstream body by some large rivets.
I'm not sure what is on the other side, but the bracket is wiggling and the caulk around it is no longer sealed.
How does one tighten this?
I have noticed on my lower end poles, both brackets have one rivet and the rest are substantial stainless philips screw heads showing. They are nice and tight.
Thanks for any tips!
groundhogy
groundhogy is offline   Reply With Quote
Old 08-11-2019, 04:10 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Those are Olympic rivets, drill out and replace. Caulk...
Old 08-12-2019, 02:10 PM   #3
Bumpy's Avatar
2003 30' Classic
Edisto Island , South Carolina
groundhogy
Any RV repair facility can make this happen. Most charge 100 - 150$ per hour. This is a 10 min fix.
Politicians, like diapers, should be changed often, and for the same reason!
Mark Twain
So 'em
Bumpy is offline   Reply With Quote
Fresh Water Leaking From Hand Tightened Fittings GinRose Fresh Water Systems 2 02-19-2018 08:52 AM
Airstream back window awning from Zip Dee Dianne_Scott Airstream Classifieds 0 11-14-2013 02:15 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 01:25 PM
