Old 03-08-2021, 06:52 AM   #21
2019 25' International
Washington , Washington, D.C.
My electric awning acted up in the early days of ownership. In conversations with the Zip Dee people, I finally figured out what to do religiously when operating the awning:
To open:
1. Push rocker "ON/OFF" switch to ON. (I understand that not all the Zip Dee awnings have the on/off rocker switch but mine does).
2. Push the "Close" button on the panel. (This resets the controls).
3. Push the Open button. (Do not keep the button pressed while it opens or closes, just a firm push will do it).
4. When fully extended, push either the "Tilt Front" or "Tilt Back" button (optional). BTW - you can extend the awning part way versus fully extended.
DO NOT MOVE THE OFF/ON ROCKER SWITCH TO OFF WHILE AWNING IS EXTENDED.
To close:
1. Push CLOSE button. (NOTE: If you tilted the awning after you extended it, you don't need to push the tilt button to straighten it as it will close properly on its own. However, I usually un-tilt it and then push the "Close" button.
3. When completely retracted, push rocker ON/OFF switch to OFF.
Definitely make sure that OFF switch is OFF when traveling.
Every couple of months, I oil the moving parts based on a YouTube I watch on maintenance.
PatLee is offline   Reply With Quote
Old 03-09-2021, 06:42 AM   #22
Grace the Airstream
2020 27' Globetrotter
To open:
To close:
Agree. These simple instructions will ensure a much smoother operations.
I too had issues until I learned to be more patient with the unit.
As stated it is finiky and like a spoiled child.
When you have the issues with it not closing all the way, I turn off the power (rocker switch) then turn it back on, hit close again and then open.
I let it complete its reinitialization process (supposedly the system is like a duck it learns its process new every time you open it )
Then it usually closes just fine.
pdavey is online now   Reply With Quote
Old 03-10-2021, 05:45 AM   #23
pdavy - thanks for the additional note on how to reinitialize the system when it fouls up.
Old 03-10-2021, 06:08 AM   #24
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Obrigado, ť hora de descansar.
Tahawus
Who has a Zip Dee Relax 12v Automatic Awning? veg hed Awnings 54 03-16-2021 05:18 PM
Zip Dee Relax Awning Dennawayne Awnings 16 09-24-2018 06:05 PM
Zip Dee Relax Awning Problem CEG Awnings 7 08-20-2018 05:19 AM
Zip Dee Relax Power Awning ksteve06 2016 - Current International 3 06-06-2017 12:51 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
