Old 08-26-2017, 08:05 AM   #1
CEG
2017 25' International
Port St Lucie , Florida
Zip Dee Relax Awning Problem
Good morning all,
I have a problem with the awning on my 2017 25FB closing properly. When the awning gets to within 8-12 inches of full closure it stops. I have to open it a few inches then close again, it then closes normally. Has anyone else experienced this issue? BTW, when I took it back to the dealer for this problem, the awning performed flawlessly!!
Thanks in advance .....
Chuck
CEG is offline   Reply With Quote
Old 08-26-2017, 08:08 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I've had mine do that once. It's run fine all the rest of the time.
Old 07-06-2018, 05:14 PM   #3
Linkís Travels
2002 25' Safari
1999 35' XL 350 w/slide
LINCOLN , Nebraska
I was told by a GM at Airstream Adventures Nothtwest that you need maximum power (voltage) when you are opening or closing the auto awning. Make sure spouse is not running airconditioner, microwave, electric heater or another strong voltage pull appliance when you use the awning.
MissingLink5 is offline   Reply With Quote
Old 07-06-2018, 06:13 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Mine does that too. I have a full lithium power system and always have a very healthy 13.2 - 13.5 volts supplied to the awning - so it is not a low power issue.
I believe the sensors get confused as to where they are in the process and send a signal to early to cut power when they think they the awning is fully closed.
As you've noted opening a bit then closing back again does the job / resets the sensors.
wulfraat is offline   Reply With Quote
Old 07-07-2018, 08:44 AM   #5
Oak Harbor , wa
Same problem occasionally
We have the Relax power awning as well. We use it often, and have twice experienced the partial closure. Opened it slightly then resumed action to full closed position.
Stormalong is offline   Reply With Quote
Old 07-07-2018, 11:22 AM   #6
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I also have a sense this is related to power. I have had this happen on a couple of occasions when retracting the awning while on battery power, even though our batteries are fully charged. I have yet to ever have this happen when we are plugged in.
thewarden is offline   Reply With Quote
Old 07-28-2018, 07:29 AM   #7
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
It has happened to us since the trailer was new almost 2 years ago. Weíre going back to the factory next month for two year warranty visit. Itís on my list so Iíll let everyone know how they deal with it. I suspect itís a sensor adjustment. Other than that quirk it works fine.
VaTravelers is offline   Reply With Quote
Old 08-20-2018, 05:19 AM   #8
2018 30' Classic
Callao , Virginia
http://www.airforums.com/forums/f442...re-185765.html
Airhead2018 is offline   Reply With Quote
Who has a Zip Dee Relax 12v Automatic Awning? veg hed Awnings 54 03-16-2021 05:18 PM
Zip Dee Relax Power Awning ksteve06 2016 - Current International 3 06-06-2017 12:51 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 01:47 PM
