Old 07-09-2020, 06:16 AM   #1
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Zip Dee relax awning and Connect system problems
I recently took my trailer to JC for warranty repairs and a few other things. I've told this story before, but I will tell it again. My wife was doing dishes with water in the sink and the whole sink dropped from under the countertop. The water splashed over the rear of the sink and onto the Czone controller and the zip Dee awning controller shorting them out. JC replaced both controllers.
When I went in to go over all the repairs, we put the awning out and back in and everything was fine. I did not check if it could do this with the connect app. When using the connect app, I can put the awning out (although the last two times I've tried, even that doesn't work) but cannot close the awning. The panel at the door works fine. The Czone panel also works fine although I have to hit the "close" button twice. It is only the app that has a problem.
If I try to close the awning with the app, I can hear a "click" under the wardrobe where the Czone switch is and maybe some relays. It has never closed once with the app. It also has stopped opening.
Any ideas?
I talked with Jason Kriezel and he hasn't a clue. He said the Czone controller for the awning is not programmable. The Czone panel is talking to the awning so why wouldn't the app that goes through the same panel do the same. I am awaiting a call from Dan at JC.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 07-09-2020, 06:53 AM   #2
2019 30' Classic
Pleasant Garden , North Carolina
Tom, I've been having a similar problem with mine, that is when I can get my Airstream connect to work. I also have a problem using the fantastic fan remotely. Now I have something else happening. When it does connect it's showing that my shore power is not connected when clearly it is. Makes me wonder what else is not accurate on this app. All of this is very frustrating when when being able to use things remotely was a big part of the reason we bought a Classic.
jlandreth is offline   Reply With Quote
Old 07-09-2020, 06:57 AM   #3
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Have you ever talked with Jason Kreisel? He's in Dallas.
Old 07-09-2020, 07:06 AM   #4
2019 30' Classic
No, I've only spoken with the guys at JC. Who is Jason with?
Old 07-09-2020, 09:34 AM   #5
2019 - 33' Classic
RickyNelson's Avatar
2019 33' Classic
Grand Junction , Colorado
Following...
Thank you!
Rick & Michelle Nelson
Grand Junction, CO
2019 Classic 33
RickyNelson is offline   Reply With Quote
Old 07-09-2020, 09:36 AM   #6
2019 33' Classic
Miami , Florida
My connect app has stopped working totally. It won't connect at all to the wifi modem. Very frustrating. I've already deleted the app and reinstalled the app several times. I've disconnected the modem several times. Still nothing.
Dog House is offline   Reply With Quote
Old 07-09-2020, 10:56 AM   #7
SHE SHED
trikdacy's Avatar
2019 30' Classic
Brooklyn , New York
Same here, both fantastic fan & awning no-op with app.
trikdacy is offline   Reply With Quote
Old 07-09-2020, 12:55 PM   #8
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
The old standby: Reboot. Make sure all electrical power sources are off. If necessary, remove the negative cable from the batteries and disconnect solar. Wait 10 seconds and reconnect everything. First press the Relax Awning control to close then open to see if it will work normally. That has fixed a lot of electrical devices that were acting screwy.
guskmg
Old 07-09-2020, 05:07 PM   #9
Bluffton , South Carolina
Following
Hope you guys find a fix!
69SoulShine is offline   Reply With Quote
Old 07-09-2020, 07:54 PM   #10
2018 25' International
Slidell , Louisiana
My guess is that there is a software or firmware (in the CZone) version compatibility issue between the app and the CZone that was installed. See if you can determine version compatibility. Next the Czone software or firmware may be corrupted. See if you can get it reinstalled. Finally the communication cable or connectors between the CZone and the ZipDee controller could be weak. Thinking about it, I might check that before reloading software and firmware.
Brian
Old 07-10-2020, 10:13 AM   #11
SHE SHED
trikdacy's Avatar
2019 30' Classic
Brooklyn , New York
From the posted comments it seems to be a problem on the 2019 Classic models. CZONE update?
Zip Dee Relax Awning Dennawayne Awnings 16 09-24-2018 06:05 PM
Zip Dee Relax Awning Problem CEG Awnings 7 08-20-2018 05:19 AM
Who has a Zip Dee Relax 12v Automatic Awning? veg hed Awnings 47 08-16-2018 08:04 AM
Zip Dee Relax Power Awning ksteve06 2016 - Current International 3 06-06-2017 12:51 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
