Old 09-27-2018, 11:53 AM   #1
2016 30' Classic
Houston , Texas
Zip Dee New Key Pad With On/Off Switch
I have heard reports of Zip Dee awnings opening while the Airstream is in transit. I am installing the new Zip Dee key pad with an on/off switch.
There are four new wires that the new keypad requires be dealt with (see attached diagram). The four wires are:
1. a black wire that connects to the top port of the keypad and to the 12V powersource;
2. a red wire that connects to the middle port of the keypad and to the Zip Dee control board (see attached photo);
3. a second red wire that connects to the bottom port of the keypad and to the control board; and
4. a second black wire that connects to the 12V power source and the control panel
My questions are several:
a) where is the 12V power source? Is it accessed via the Zip Dee control pad? If yes, where on the control panel can it be accessed?
b) regarding wires #2 and #4, exactly where on the control pad do these two wires connect into?
Thanks for any assistance you can provide.
Name:	zipdee diagram.JPG
ID:	323837   Click image for larger version
Name:	zipdee control panel.jpg
dhroberts is offline   Reply With Quote
Old 02-26-2020, 09:51 PM   #2
I would also like to add this pad. Did you purchase the new pad from Zip Dee and how much was it?
firemed509 is offline   Reply With Quote
Old 02-27-2020, 07:27 PM   #3
2016 30' Classic
Houston , Texas
I did purchase the new pad from Zipdee. Don't have the receipt. Cost was reasonable.
Zip Dee Flex Key Beaubill Awnings 1 01-20-2012 10:55 AM
ZIP DEE flex key on a Care Free awning?? larry b Awnings 6 04-03-2010 09:05 PM
Need Info on Keyless entry key pad removal papademojo Doors & Locks 0 01-24-2010 02:05 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee fell off!!! SilverToy Awnings 12 07-06-2007 12:07 AM
