Old 03-25-2023, 08:08 PM   #1
hikingcamera's Avatar
2022 23' Flying Cloud
Seattle , Washington
Zip Dee locking knob fell off
So, not quite sure how this happened, but one of the knobs that is meant to lock the ZipDee awning down in transit fell off after getting the trailer back from the dealer. We are at a campsite now and I want to ensure I don’t lose the awning on the way home. I’m thinking I’ll try to strap it down perhaps… anyone have some advice on how to provide some backup to that missing knob?
hikingcamera is offline   Reply With Quote
Old 03-25-2023, 09:29 PM   #2
Escape Pod II
John Ware's Avatar
2018 22' Sport
Orange , Texas
Can you put a regular nut and washer on it? Perhaps a fender washer? One of mine loosened up and opened up on me once but didn't fall off.
JEWare
John Ware is offline   Reply With Quote
Old 03-25-2023, 09:43 PM   #3
2016 16' Sport
Miami , Florida
A big wire tie around it.
Shiny16 is offline   Reply With Quote
Old 03-25-2023, 09:51 PM   #4
If I were home I’d have lots more options. I don’t think I have the right sized nut on me. Also not sure about a zip tie, but that would probably be ideal. I might have some straps. Lesson learned, gotta hand check those after picking up from the dealer.
Old 03-25-2023, 09:53 PM   #5
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
I have forgotten to lock down the awning a couple times and one of the trips was 1k miles. With the amount of spring tension pulling that awning tight to the side, I highly doubt you have anything to worry about. Just order another lock from ZipDee and install it when it arrives.
- Stewart
s1000pre is offline   Reply With Quote
Old 03-25-2023, 10:48 PM   #6
Escape Pod II
John Ware's Avatar
2018 22' Sport
Orange , Texas
I would try to tie it down with something. Have any tape you can wrap around the tubing? I discovered mine loose when I heard it banging by the wind while camping.
JEWare
Old 03-26-2023, 01:40 AM   #7
I definitely can find something: cord, probably a webbing strap. Securing it and making sure nothing that can damage the body is dangling may require more effort.
It is luckily the arm under spring tension, so that helps. Though I could always move the other if it weren’t. And it’s the side near to the security latch. So it is pretty secure already. I’d still feel more comfortable with a strap of some kind holding it down.
Old 03-26-2023, 08:29 AM   #8
Mollysdad's Avatar
I'd get a very large cable tie, loop it twice through the clamp and roller casting and pull it tight.
Zip Dee will sell you another wheel.
Old 03-26-2023, 08:29 AM   #9
CRH
1995 25' Excella
xxxxx , xxxxxx
I'd put a couple of zip ties under the arm pivot bolt and around the arm.
CRH is offline   Reply With Quote
Old 03-26-2023, 09:10 AM   #10
Saluda372's Avatar
2021 20' Caravel
Plaistow , New Hampshire
Would definitely secure it, wire ties are great as already stated.
Learning and enjoying as we go !
Saluda372 is offline   Reply With Quote
Old 03-26-2023, 09:21 AM   #11
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
If you are close to a Home Depot or Lowe’s, get some Velcro to wrap around the awning arms. We do this even with the lock down knob.
banderabob is offline   Reply With Quote
Old 03-26-2023, 09:29 AM   #12
2015 25' FB Flying Cloud
Cedar Rapids , Iowa
Zip Dee clamp wheel. Google it and you’ll find many sellers. It happened us too. I used a spare dog collar around the awning posts to get home. Now I use the clamps again but put a zip tie around posts and up through the wheel so it cannot turn once the zip tie is pulled tight
Kemmy
Oh the places we’ll go!
Kemmy is offline   Reply With Quote
Old 03-26-2023, 10:06 AM   #13
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
Looking at your bolt, it appears to be at an angle. It should be centered. Look at the opposite side and is it also off at an angle?
Look at the top where the nut and bolt secure to the casting. Is it wearing off center? If so, you may begin to figure out why the awning is not square with the side of the trailer.
Are either of your supports on the left or right side, bent? Often bent from a wind putting pressure on the awning when extended.
The sliding rods to increase the angle of the awning would be difficult to slide down due to a bend. It will be easy to find, as when it gets to the bent rod, it is difficult to slide into the housing that it is fitted.
I much prefer your kind of manual awning. The electrical awnings are my least favorite, but came with the 27FBQ.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 03-26-2023, 10:13 AM   #14
Escape Pod II
John Ware's Avatar
2018 22' Sport
Orange , Texas
The left side of mine was off center as well. I unscrewed the bracket from the roof and moved it over to properly center the wheel nut.
JEWare
Old 03-26-2023, 10:23 AM   #15
"Cloudsplitter"
I use a heavy duty removable zip tie from Amazon...
Learned a lesson...now zip & make sure the wheel is tight.
I also had to move the rear lower mount to get the assembly plumb. Lock wheel off line and the awning rolled up cock-eyed.
ID:	429480   Click image for larger version
"You don't know where you've been until you leave, enjoy life" RLC
Old 03-26-2023, 01:26 PM   #16
2023 23' Flying Cloud
Arlington , Texas
My bet is someone camping near you has zip ties to share.
Escape21 is offline   Reply With Quote
Old 03-26-2023, 04:28 PM   #17
Well I had some Velcro, so I ended up using that to get home. No incidents. Not a bad idea to put something on there during normal travel as well, just in case.
As for the angle. I mean, pictures like that can be hard. I was taking it from an angle myself. But I do know the arm on that side is bent. On my list to fix that when I have a second person to help. I’m not really sure what normal looks like.
I’ll be ordering two wheels so I have a backup on hand. Plus adding some zip ties to my truck tool kit.
Old 03-27-2023, 08:32 AM   #18
2018 23' International
Pensacola , FL
It is very sad that service is not what most of us grew up experiencing. I can tell of accounts that would just make your jaw drop concerning the condition of my Airstream after going to an authorized Airstream repair shop in south Florida, but I suspect nay others have incident reports just as well.
Joseph Sessa is offline   Reply With Quote
Old 03-27-2023, 08:59 AM   #19
Mollysdad's Avatar
I was at the dealer's service center to see if they understood the problem with my awning. (long story). They couldn't figure it out and I drove the three hours back home. After storing it, I noticed they did not even latch the front locking wheel. Amazingly, it didn't blow open on the way home.
Always check for your self. Don't assume the dealer wouldn't screw up.
It's a hundred year old design and not made to tolerances. I've ordered replacement parts from Zip Dee and the pre-drilled holes don't match up. There's factors you have no control over. The roller might be two inches longer than perfect, so one arm is angled. Zip Dee is not full of laser guided cutting machines. I'll bet it's more like a guy with a hacksaw, "This looks about right."
I'll still take it over the "automatic" version.
Be happy if the darn thing unfurls and furls.
Here's mine.
Old 03-27-2023, 09:15 AM   #20
1987 34' Limited
Hantsport , NS
We have that large one on the curb side on our 1986 34'-er. You can take the wheel off of the other side, go to a hardware store, and get a nut with the right thread pitch and size. As mentioned a fender washer or heavy zip tie will work.
On the street side front half we have a 12' Zipdee but with no locking wheels. With the interior walls out I noted the installation is with olympic rivets, where I had expected buck rivets. Maybe that's a good thing as perhaps it allowed the awning to let go vs really messing up the sheet metal, or beating out the windows. Over this winter a 100 kph+ wind opened and got under the street side spring loaded awning - tore it completely off the trailer, heaving it front of our car. This wind also blew the front of the trailer sideways into my truck, despite wheel chalks. An easy repair to the trailer with the inner skins out, but not the truck door.
All this to say that if the right wind gets under one of these large parachutes, not good.
Daytonacoupe is offline   Reply With Quote
WTB (want to buy) - Locking Pin + Chesler T-5 Locking Pin Billyjchase Doors & Locks 10 06-29-2020 08:16 AM
Issue with zip dee awning, hold down hook fell off waninae39 Awnings 37 11-03-2019 08:45 PM
Need Shower Door "Locking" Knob for 2004 Classic montanapat Cabinets, Counter Tops & Furnishings 6 06-17-2015 04:33 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee fell off!!! SilverToy Awnings 12 07-06-2007 12:07 AM
