Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-30-2018, 09:49 AM   #1
Loretto , Tennessee
Zip Dee Awning Repair
My awning got to where it would not retract without help. I figured the spring was broken. After disassembling, the spring is in tact and nothing appears broken. At the far end of the spring assembly, there is an end that fits onto the center wooden rod. The end is metal and has three ears which grab a pin that is attached to the awning tube (that it slides into).
Here is my question: Is the metal end supposed to spin freely around the wooden rod? I think it should. I can't see any other way to load tension onto the spring.
1989 Excella 25'
TNExcella is offline   Reply With Quote
Old 06-30-2018, 11:21 AM   #2
Loretto , Tennessee
OK, I think I'm past the question in the original post. Answer is YES it is supposed to spin. My reasoning is this: when I took the metal end off, a small disc of teflon or plastic fell out. It had a bit of white grease remaining. Also there was a metal brad tapped into the very end of the wooden shaft. To me this means it is intended to rotate/spin. So I sanded the wooden shaft to a point where the metal end spins when placed back onto the end of the wooden shaft.
2nd Question: To put the end cap back onto the awning tube, can I use pop rivets or do I need a different type?
1989 Excella 25'
Old 06-30-2018, 12:32 PM   #3
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I cant answer, due to lack of experience with your issue.
But, this might help.
http://nebula.wsimg.com/204793e082e5...&alloworigin=1
There are at least three different types of springs, so this might not be the correct one. An example:
http://nebula.wsimg.com/2bbf03ef39d4...&alloworigin=1
These documents came from ZipDee's website. It takes some effort to search through everything that is there (not user friendly IMO). I spent some time searching earlier this year when I removed one of the smaller awnings on my Excella.
This video shows the problem, but not the fix, if anyone is curious.
Alan
Old 06-30-2018, 01:55 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
On my 2 awnings the end of the awning away fron the spring was causing the problem. Told the lock end out of the roller tube, drove the shaft out of the bearing, cleaned and lubed, and the awnings work fine now.
And yes just pop rivets work fine to hold the ends in the tube.
Old 06-30-2018, 03:57 PM   #5
Loretto , Tennessee
Alan, thanks for the links. I'd already seen the Youtube video and was disappointed they didn't show the process of repairing it.
Bill, thanks, that's what I was hoping. I have a pop rivet kit so will use what I have. FYI, my 500 pc rivet kit comes with I guess standard sizes of which the largest is a 3/16 x 3/8. I will have to drill out my awning's holes to make these fit. No problem.
1989 Excella 25'
Old 07-01-2018, 11:48 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
If you call ZipDee, they will help you.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 07-05-2018, 09:25 PM   #7
Loretto , Tennessee
Putting it back together
Our awning had another issue. On the end towards the rear of the trailer, the fabric had pulled out of the aluminum channel about 2'. Upon inspecting this, I found there is a plastic/rubber tube about 3/8" diameter sewn into the fabric. This tube is what holds the fabric in the channel. The tubing had simply disintegrated. We ordered the tubing from Zip Dee and my wife used her portable Singer to sew it in. Worked like a champ once we got everything set up. She used upholstery thread and a heavy needle.
We discussed the merits of removing all the old tubing and putting in one continuous length of the new tubing. I mashed around on the old stuff and it seemed pretty flexible and in tact except for the very ends. We decided to just replace the ends...both ends. We may wind up redoing this but now that we have some experience it shouldn't be that bad.
1989 Excella 25'
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Zip Dee awning repair. ck21084 Awnings 7 04-09-2012 08:16 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee Awning Repair - Golf Cart Accident jbbaldwin Awnings 0 08-15-2011 01:16 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
