RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-15-2020, 04:58 AM   #1
1976 29' Ambassador
Fort Wayne , Alabama
Zip-Dee Awning
Yesterday, we pulled out our awning only to have the awning roller detach from the support arm connected to the trailer. Appears the bolt broke. We got the bolt replaced. However it appears the tension or spring inside the roller will now not retract up. So we can not close the awning up.
Is there a way to safely rewind the spring inside? WE do not want to have to buy a new awning as ours is in great shape
Thanks for any help, videos, or suggestions
Travel safe
Tommy1962 is offline   Reply With Quote
Old 06-15-2020, 07:18 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Contact ZipDee for the number of rotations you will need. All new seeming springs must be “charged” , but there is a specific number of rotations needs
Old 06-15-2020, 08:47 AM   #3
1976 31' Sovereign
Oswego , Illinois
Thumbs up
Google Zip-Dee, there is a very good vid. how to repair, also pdf, or phone Zip-Dee at 800 338 2378 or 847 437 0980, they can tell you all you will need to no, as they are very customer friendly.
Old 06-15-2020, 09:11 AM   #4
Mollysdad's Avatar
Originally Posted by Tommy1962 View Post
.. it appears the tension or spring inside the roller will now not retract up. So we can not close the awning up.
Travel safe
I know something about this having done it many times.
You'll need a small wrench for the nuts/bolts, and a small Phillips screwdriver to help align holes.
First, remember the spring under tension is very dangerous, letting it get away could be a trip to the hospital. Never stand where the rotating parts out of control will hit you or a helper. Nothing requires much strength, but winding does take some energy.
Now, Get a helper or stepladder to support the tube. Remove the upper arm bar (the part with a dogleg) from the main arm tube. (The square tube holding the arm bars) This will be your "lever".
Zip Dee will tell you that the number of turns is 1 per foot of awning length + 7. In other words if your awning is 15' long, then you'll wind it 22 turns. (It unwinds 7 turns as it leaves the trailer.)
I found this to be a rough estimate, and later had to adjust one turn or so.
Put the upper arm bar into the head casting and secure with the 1/4 bolt. Start winding. Mine was the rear, and I had to wind clockwise. Think about how the tube rolls and allow that to happen.
After your number of turns, stop. The upper arm bar is too long to fit within the main square tube, so remove the lower bolt holding the awning arm to the trailer. (Better to do this first) Slide the arm into the tube to the last hole, and re-attach the arm to the trailer.
Your awning should roll up!
http://nebula.wsimg.com/36853a1e4185...&alloworigin=1
If this doesn't make sense, feel free to PM me.
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 03:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 11:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 09:12 PM
Zip-Dee Awning Repairs ViewRVs Awnings 3 08-31-2006 07:28 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 02:47 PM
