Old 03-28-2017, 07:26 PM   #1
jholder's Avatar
2009 27' FB International
Murfreesboro , Tennessee
Wind tore awning at seam--repair?
Last night while we were gone, a storm shot across the lake out of nowhere. I pulled up at just the right time and got our awnings closed, but the smaller one on the side opposite the door whipped and ripped along about 25%. How in the world would I repair?
First time I forgot to put awnings away! Could have been worse! Click image for larger version
Name:	ImageUploadedByAirstream Forums1490750794.400724.jpg
ID:	282279Click image for larger version
Name:	ImageUploadedByAirstream Forums1490750808.701902.jpg
jholder is offline   Reply With Quote
Old 03-28-2017, 07:41 PM   #2
dznf0g's Avatar
Oswego , Illinois
That thin strip of fabric with twin beads is available from zip dee. The entire awning roll must be removed to slide in a new strip. Study up on how to remove the awning safely, as the roll is under spring tension. Best to do this with 2 people.
-Rich-
Old 03-28-2017, 07:43 PM   #3
dznf0g's Avatar
Oswego , Illinois
It is common for this strip to deteriorate over time, as it is expose to the elements and sunlight.
Probably time to replace them all as a preventative measure. If one is weak, the rest are too.
-Rich-
Old 03-28-2017, 07:43 PM   #4
jholder's Avatar
Thanks so much! Would this most likely mean the entire fabric of the awning will have to be replaced? Wasn't sure if it's one piece design.
Old 03-28-2017, 07:45 PM   #5
dznf0g's Avatar
Oswego , Illinois
Probably not, as the rest of the fabric is protected by the metal cover when rolled up.
-Rich-
Old 03-28-2017, 07:46 PM   #6
jholder's Avatar
Ah. Ok. I hadn't inspected closely yet, as I wanted to let it rest some today. Ha!
Old 03-28-2017, 07:47 PM   #7
dznf0g's Avatar
Oswego , Illinois
Zip dee has repair instructions on their website.
-Rich-
Old 03-28-2017, 07:49 PM   #8
jholder's Avatar
Thank you so very much for taking this time!
Old 03-28-2017, 07:49 PM   #9
dznf0g's Avatar
Oswego , Illinois
No problem!
-Rich-
Old 03-28-2017, 10:34 PM   #10
CRH
1995 25' Excella
xxxxx , xxxxxx
Check the awning seams. At the 20 year mark, the threads in my awnings seams were rotten. The fabric was solid. I had to have it restitched.
CRH is offline   Reply With Quote
Old 03-29-2017, 06:47 AM   #11
dznf0g's Avatar
Oswego , Illinois
OP's trailer is a 2009....so I doubt the seams are rotten, unless the awning has been deployed an inordinate amount of time. However, his experience with the connector section makes me suspicious of my 2007, which has been outside most of its life.
-Rich-
Old 03-29-2017, 06:56 AM   #12
jholder's Avatar
Name:	ImageUploadedByAirstream Forums1490792079.768999.jpg
ID:	282318Click image for larger version
Name:	ImageUploadedByAirstream Forums1490792102.005803.jpg
ID:	282319Click image for larger version
Name:	ImageUploadedByAirstream Forums1490792115.588847.jpg
As always, looks like you guys were right :-) hopefully it is just that strip next to the track and then connects to the metal flap. While not used a lot, this one did sit in Miami for several years and I think received some dry rot issues.
Old 03-29-2017, 07:03 AM   #13
CRH
1995 25' Excella
xxxxx , xxxxxx
FWIW.... The strip is called Flex Key
Old 03-29-2017, 07:13 AM   #14
jholder's Avatar
Thanks SO much.
Old 03-29-2017, 07:13 AM   #15
jholder's Avatar
So relieved it's not a full replacement! Thank you Lord!
Old 04-14-2017, 12:15 PM   #16
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I just received a new 'flex key' from ZipDee for our street side awning which tore. Thankfully, we do not expect more damage.
ZipDee sends the replacement promptly. You will need the width and length of the Flex Key... then ring them up..
I will do ours after Easter... If possible, I will video the process... at least the steps, not all the fussing and beer drinking....
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-03-2017, 06:24 PM   #17
A W Warn's Avatar
Two Places , Sticks & Bricks
Channing,
Did you make the video of the flex key replacement?
I rolled out my longest curb side awning this afternoon. The 2" cloth part is ripped at one end and has a hole near the center of the awning. The hole is large enough that a tree frog moved in
Looks like replacement is going to happen soon.
Any advice/instruction would be appreciated!
Thanks!
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Top wind or Side wind? kirkrik Hitches, Couplers & Balls 14 08-11-2015 08:40 PM
Tore out the carpet and then........... Akronguy Repairing/Replacing Floor &/or Frame 8 05-17-2014 07:10 PM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
Tore out the Gaucho today... Mexray Upholstery, Blinds, Walls & Interior Finishes 10 07-07-2009 09:02 PM
moved and tore loose what happened overlander General Interior Topics 5 09-24-2002 06:50 PM
