Old 12-04-2017, 05:43 PM   #1
A W Warn's Avatar
Two Places , Sticks & Bricks
Wear Tape Beneath Awnings
I have removed the awnings from my Excella since the cloth flex keys are decaying and torn. After I removed the awnings, I noticed the protection tape beneath them is noticeably shrunk and UV damaged at each end where it is exposed.
Airstream calls this tape "wear tape, clear, 3.5" wide".
Airstream part number is 385577.
It is sold in 150 ft rolls, at ~$230 per roll, not by the foot. I only need 50 ft for all five awnings.
Has anyone found a substitute wear tape material?
Automotive paint protectant film was my first thought, but I can not find it in the proper width or in a full length, except bulk quantities. The longest awning is ~22'. I do not want to have joints in the tape, so the minimum material length must exceed 22'. The tape extends under the awning rails about 0.5". I do not intend to remove the rails, so I suppose a 3" width will be sufficient. I found a 14 mil UV resistant polyurethane tape, called helicopter blade leading edge protectant tape, 3" x 60', that is a possible substitute, but I know nothing about how the tape's adhesive will react with the acrylic clear coat finish on the aluminum.
I would appreciate your suggestions or thoughts.
Thanks!
add edit:
The original material seems to be 6-8 mils thick.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Old 12-04-2017, 06:20 PM   #2
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
High Speed Tape
In the aviation industry this is called high speed tape made by 3M - 3M POLYURETHANE PROTECTIVE TAPE 8672- It is available in smaller rolls from Aircraft Spruce. I have flown aircraft at Mach.84 with this stuff and it never peels away.
fltlevel510 is offline   Reply With Quote
Old 12-04-2017, 06:23 PM   #3
A W Warn's Avatar
Thanks!
I feel homeless
Alan
Old 12-07-2017, 12:52 PM   #4
A W Warn's Avatar
I found what I hope is a suitable substitute at https://www.pilotshop.com/catalog/cs...ngedgetape.php
6 mil and UV resistant.
I'll be installing it later this winter. I'll report on quality and post photos then.
I feel homeless
Alan
Filled tank, water pouring out beneath mutcth Fresh Water Systems 33 03-30-2013 02:52 PM
What's beneath this DryFly General Repair Forum 11 10-20-2012 05:44 AM
Constant leak beneath the Kitchen 73 31ft Sovereign Advice desperately needed barender Fresh Water Systems 10 05-26-2011 01:15 AM
Specs? Blue Prints? What lies beneath the floor... mrsdinapoli General Interior Topics 6 01-18-2010 09:48 PM
Water leak beneath windows Ann Windows & Screens 3 08-02-2003 04:21 AM
