Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 01-09-2021, 04:06 PM   #1
1952 25' Cruiser
1967 22' Safari
1969 18' Caravel
Palo Alto , California
Vintage Dometic awning Mechanism
Hi,
We are looking for an older (vintage?) Dometic (A&E) awning. The one we would like has curved legs (at the top) and the bottoms of the legs can be removed from the body of the airstream and set on the ground. We know this exists because we have on on our '67 Safari and would like to purchase another one for our '52 Cruiser.
Any help would b greatly appreciated!! Thanks you! Mark and Denise
markdenise is offline   Reply With Quote
Old 01-09-2021, 05:39 PM   #2
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
Following
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 01-10-2021, 07:03 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Suggest you talk to a Dometic dealer. It is getting hard to find reference to the old style awning arms used back then. I have an old catalog that shows the various arm shapes/sizes. I'm not sure if they still make all of these.
Dometic catalog.pdf
The awning arms are on page 33 & 34. Look at the mounting instructions on page 37. The main consideration is the measurement from the floor of the trailer to the upper mounting point (which should be centered on the mounting rail. The awning arms show a range that the arm fits.
Arm 015 is listed for Airstreams thru 1985 (Min 75-5/8 Max 81-5/8). That is too long for my 58. I ended up buying a set of these arms on Ebay (freight damage, coating scratched) and shortened both ends to fit. Not an easy solution.
Name:	Modified awning arm upper.jpg
ID:	386624 Click image for larger version
Name:	Modified awning arm.jpg
Hopefully a dealer can find you an easy solution.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 09-07-2021, 01:26 PM   #4
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
I know this is a little old but did you find the arms? I bought a 78 and I think it has the arms you’re looking for. I’m removing it to install a Zip Dee
CaCraig is offline   Reply With Quote
Old 09-10-2021, 06:17 PM   #5
1952 25' Cruiser
1967 22' Safari
1969 18' Caravel
Thanks so much!
We went to an RV junk dealer and found almost all of the parts. Mark customized a few things and our awning i perfect.
Thanks so much for thinking of us!
Awning Mechanism Bombcity806 Airstream Classifieds 0 02-13-2017 09:33 PM
Awning window mechanism glh101282 Windows & Screens 5 07-31-2014 03:38 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
What is the best locking mechanism for cabinets? pamelake Cabinets, Counter Tops & Furnishings 4 02-10-2007 07:14 PM
