Old 09-02-2023, 02:46 PM   #1
2015 30' International
Escondido , CA
traveling with broke zip dee awning
Streamers,
Of course your Zip Dee Relax awning fails on the Friday night before Labor Day weekend. Thankfully the awning arms were down when it failed, so all I had to do was pull off the pressurized support arms and find a 1/4 20 bolt to use in stead of the winding emergency tool (I never received from the previous owner) on my pre 2016 Zip Dee powered awning. With the awning rolled tight to the Airstream, the next step was to figure out how to travel with the fully extended support arms. I realized that if I removed the connector from the trailer and connected them to the support arms, I could compress the poles and tie them down with rip cord. Then it dawned on me that would be a great technique to use for reinstalling the support arms when I got to that point in the repair. Then is dawned on me, wouldn't it be more likely that the awning wouldn't extend during travel if I reinstalled the tied down and compressed support arms.
What am I not thinking of here, it would be very simple to remove them and store in the back of my truck if I'm way out in left field.
Please comment as kindly as you can.
Name:	zip dee compressed awning pole.jpg
dsatwork is offline   Reply With Quote
Old 09-02-2023, 06:03 PM   #2
2024 30' Globetrotter
Houston , Texas
You might want to consider using some long tie down strap s typically used for roof rack tie downs and lash the failed awning over the roof and tie it off to the road side awning. It would give some extra security.
FredWilma is offline   Reply With Quote
Zip Dee Support Hook Broke What To Do? mrpettit Awnings 33 06-06-2016 02:09 PM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee awning pull strap broke ? Davis Awnings 13 12-26-2009 04:57 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
