2006 28' International CCD
1976 Argosy 28
1972 Argosy 24
Chico
Snap stud assembly Zip Dee awning
Hi all,
The outer knob of the snap stud assembly pulled off the pin, then the pin (spring loaded) went inside of the assembly. The assembly is shaped like a nut, but putting a wrench on it there is a lot of resistance, so I am not sure if it unscrews or not. Part number from Zip Dee is Y 290002
Anyone ever have to pull that out and replace it? https://photos.app.goo.gl/Uo7N64972wrdaHK77 https://photos.app.goo.gl/Cz7j5ZsqiDNNyqvi7
I've had mine out and yes they screw in to the arm. The ones on the tension bars have a small pin in the round knob that keeps it from rotating so the plunger will be orientated to lock into the notches of the arm to keep the awning tight.
Mine did the same thing last year. It screws out and the new one screws back in.
Call Zip Dee directly to get the replacement. They are supper nice people, work hard to help everyone out, and will get you the part quickly where ever you are.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
