09-22-2024, 02:01 PM
2017 27' International
Lewes
, Delaware
Rubber Cap on Rear Window Awning Props
I have a 27' 2017 International.
The rear window awning uses two rods to prop the awning open once deployed. The two rods have rubber caps on the ends that stick into cups to hold the prop in place. The rubber caps wear through on the very end. I have covered the exposed rod ends with electric tape. Does anyone know a source for the rubber caps? See photo, sorry the photo loaded sideways, if you click on the photo it will be upright.
Bella and the Beast
Bella - 2017 International Serenity 27FBQ
Beast - 2017 GMC Yukon Denali
09-22-2024, 03:11 PM
2024 27' International
Noblesville
, Indiana
I would check an auto parts store.
They may have rubber vacuum plugs which might work better than the harder plastic type.
I may have some here (I have a ton of that kinda stuff from my working days) but I don't have my trailer here to confirm what I have will fit.
If I get the trailer here, and think of it, I'll check to see if I have any and also check if you've found any yet.
09-22-2024, 04:48 PM
2013 25' FB Flying Cloud
Longmont
Call or email Zipdee. When I contacted them years ago, they sent me a handful for free.
09-22-2024, 06:52 PM
Noblesville
, Indiana
That's a much better idea than mine.
09-22-2024, 07:04 PM
2022 25' Flying Cloud
Tualatin
, Oregon
Search Amazon for "Vinyl End Caps Screw Protectors"
Find the size you need, I think I bought 3mm - 1/8"
Steve
09-22-2024, 08:36 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
If you send me a PM with your address I will mail several of them to you.
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
09-23-2024, 10:40 AM
2016 28' International
Trois-Rivieres
, Quebec
Kudos for pointing out one of the annoying things that we have to deal with. Don't remember anyone ever pointing it out on Air Forums before.
Will be contacting Zip Dee, because I've tried different solutions, but none last and while you set the rod on one side, then adjust the other side, the first one slips out, and you may be going back and forth.
There should be a clip where you set the rod, clip it in place, and set the second rod and clip it into place. Hey, there could be a patent on that!
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
09-23-2024, 11:01 AM
Bompagene
Pahrump
, Nevada
Rubber tip alternative
I have used this stuff to do just what you want as well as MANY other uses. A little more expensive than just the little tips, but you will find it very useful as it will for example penetrate joints in various connections (I use it brushed on electrical connections that heat shrink just isn't good enough for), dip a crank handle or any tool for a much more comfortable and safer grip.
https://www.harborfreight.com/14-1-2...lack-2779.html
Things are more like they are today than they ever have been.
09-23-2024, 06:07 PM
2021 25' International
Sandy
, Utah
End caps
I got mine from Amazon, got an assortment and put three on each rod increasing in size on each one two years ago. They have not worn through.
09-23-2024, 07:08 PM
2020 23' International
Garland
Woodland Airstream
09-23-2024, 07:52 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Parts
https://www.woodlandairstream.com/we...iety-of--parts
Ace Hardware or Home Depot, Lowes. In a pinch got to an automotive parts store
Or fine some hard rubber tubing cut to length needed slip it over the ends
09-24-2024, 08:36 AM
2018 30' Classic
bayfield
, Wisconsin
You can find them at a hardware store .... before installing new ones , fill 1/4 full with liquid tape .. they won't slide down and poke thru ..
09-24-2024, 12:01 PM
Lewes
, Delaware
Thanks for all the replies. I contacted Zip Dee and they are sending me some caps at no charge. Nice folks.
Bella and the Beast
09-29-2024, 10:22 AM
2023 33' Classic
Chandler
These 'Cap Plugs' are the cheapest they can use, ive had mine on my 2023 Classic 33 replaced twice now within a year because they just wear through. I do have the hookup through. www.caplugs.com
The VC series, is what you want. They do send out free samples, and they do come in a plethora of colors and thicknesses.
09-29-2024, 11:57 AM
2016 27' International
San Anselmo
Rubber caps on awning
Every Ace hardware and most home repair centers stock these different size tips in their fastener section, in those slide out boxes.
09-29-2024, 01:18 PM
Fayetteville
Awning Props
Go to Lowes and take one of yours with you to compare. I bought replacements on their hardware aisles in those specialty drawers that they have
09-30-2024, 05:52 AM
2023 23' International
Englewood
Find a close by person with a 3D printer and have them make some with TPU filament if nothing else works.
WBCCI 6561
09-30-2024, 03:29 PM
Durham
, Connecticut
the wire shelving that is sold at HD or Lowes includes small white rubber tips that I have used in other applications. Try them, they are cheap. You can buy them separately.
