Old 02-24-2017, 04:20 PM   #1
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Retrofit kit for zip Dee
Has anyone put the retrofit kit on to convert your manual awning to a 12v electric? Worth it?
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 02-24-2017, 06:42 PM   #2
1976 31' Sovereign
Fuquay Varina , North Carolina
Interested in converting ours on our 1976 to automatic also. Anybody with real experience have any suggestions?
Thomas31 is offline   Reply With Quote
Old 02-26-2017, 10:50 AM   #3
walker's Avatar
1987 34' Excella
Asheboro , North Carolina
Also looking for anyone that has tried the retro fit automatic awning on older now wide body. Zip Dee says will not work due to the center arm that will interfere with the door opening. Have considered just leaving off that arm. Expensive gamble.
walker is offline   Reply With Quote
Old 02-26-2017, 11:35 AM   #4
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
We have wondered the same thing.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 02-26-2017, 06:53 PM   #5
1976 31' Sovereign
Still looking for real world experience, but I am planning to raise the rail of the awning up to the rivet line for the center roof section. This will raise the awning enough to keep the door from hitting the center support arm, the only reason I have heard as to why "it won't work." That will be about 4-5 inches higher up the side/roof of the trailer, then just fill in the old rivet holes. You will not notice the line of rivets and it will be above the Vista windows to allow better lighting there also.
Thomas
Old 02-26-2017, 07:07 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Seems like an expensive fix for a non problem. Takes less than minute to put mine out or in. Mine does not hit the door when properly raised to the 4th hole on the front most bar.
MICHAEL
Old 02-26-2017, 08:00 PM   #7
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Agreed. Just one more thing that could break, and it does just take a minute or two to deploy or put away the main awning.
SeaLevel is offline   Reply With Quote
Old 03-01-2017, 08:35 AM   #8
Florence , Alabama
Got a look at the install instructions for the retrofit kit and it seems to be a lot more than I want to take on at this point. Also was told by ZD that Airstream did not preside my AS so that introduces another challenge.
Old 03-01-2017, 03:32 PM   #9
Florence , Alabama
Prewire
Zip Dee Awning Retrofit to 69 Globetrotter gnmostream Awnings 2 02-17-2015 08:53 PM
Zip Dee Electric Awning Retrofit jschelle Awnings 7 03-18-2014 07:34 AM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip Dee retrofit 59er Awnings 5 07-18-2007 02:05 PM
