Old 05-26-2018, 07:36 PM   #1
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
repairs to upper zip dee awning hold down mount.
So the rear hold down mount for the curb site awning on my 2005 classic has been showing some signs needing some love.
It has been getting harder to get the upper clamp down part and the roller head to be in correct position. I have to push the arm in towards the shell to get the hold down part in place to tighten the round part.
So i tried to tighten up the screws (3) and found out 2 of the three will not tighten so they are stripped. I took the clamp assembly off and the metal behind was ugly..
The top clamp had three screws in it and there appears to be another place to drill through for new screw.
I was going to clean the old mess up, drill out for 4th hole, put some SikaFlex 221 on back of clamp, put the screws back and put in new screw, seal around the edge of clamp with 221, let dry for 24 or more hrs before using.
has anyone done this as well?? how did you do it, what did you use and how is it holding up??
ID:	312087   Click image for larger version
ID:	312089   Click image for larger version
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 05-29-2018, 01:08 PM   #2
carl2591's Avatar
2005 31' Classic
So after a day or three of rain I am getting back to this project.
Got by lowes and got some 14 3/4 SS Pan head screws to replace the 12's in there that had gotten loose and not holding good.
I did have to enlarge the existing holes and drill through the clamp to create another hole for one of the 12 screws.
Got it cleaned up and sprayed some brake cleaner on both part to make sure there was no oils, applied some 221 to back and screwed on the shell..
got some excess and just took finger to smooth out to seal it all up. Some came up through the screws a well so even better.
now to let it sit for 7 days according to tube for max strength.. Will be taking back to storage location adn will leave the arm off and not screw in to clamp..
should be fine as the front clamp is good and tight and rear travel lock in engaged.
here are more pictures.
ID:	312379   Click image for larger version
ID:	312381   Click image for larger version
Carl, Raleigh NC
Old 05-29-2018, 02:26 PM   #3
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
Great job carl2591! Excellent process and photos. Thanks for sharing.
vintagemotor is offline   Reply With Quote
Old 05-29-2018, 03:28 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
Good work!
Larger diameter screws is what I did too.
Alan
which way does rear awning rail mount for Zip Dee? Mixter Awnings 11 11-05-2013 03:55 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip-Dee Awning Repairs ViewRVs Awnings 3 08-31-2006 06:28 PM
cut down a zip dee awning? Jada Awnings 4 08-07-2006 04:52 PM
Zip Dee awning repairs Mariner Awnings 1 07-13-2004 08:55 PM
