Old 05-20-2023, 09:04 PM   #1
2000 19' Bambi
2018 23' International
Auburn , Maine
Relax awning arm replacement
Sometime this week Iím going to undertake to replace the forward arm on the ZipDee Relax awning on our 2018 International Serenity 23FB Queen. It looks like a pretty straightforward job, assuming that the wiring is accessible under the head of the bed, as I believe it is. But I thought Iíd ask here if anyone has done this and has any tips to make the job go as smoothly as possible. Any advice out there?
Film Maker,
Photographer,
Lover of Mid-Century Design
especially our Airstream
blog: https://airstreampictures.typepad.com
FilmGuy is offline   Reply With Quote
Old 05-21-2023, 02:51 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
I called ZipDee before I switched my rafter arms around. They were very helpful with details on things to watch out for.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-21-2023, 09:44 AM   #3
2000 19' Bambi
Auburn , Maine
Iím very impressed with their customer service folks. They were incredibly helpful in troubleshooting my awning.
Film Maker,
Photographer,
Old 05-21-2023, 11:11 AM   #4
2017 25' International
West Lake Hills , Texas
Yep. Call Zip Dee. I once spent an hour on the phone with Randy while we walked through a tricky situation that he had not encountered. At one point he checked with manufacturing to get input. Ultimately we agreed that the only solution was to execute the risky, somewhat dangerous procedure as safely as we could. I had to remove the rear head casing without releasing tension. It had been damaged.
Support the loose end of the roller with a heavy step-ladder.. Securely tie the roller to the step-ladder; you don't want that thing getting away from you. You don't want the whole shebang to hit the trailer so maybe put some weight on the bottom step and brace of the ladder. I don't know what the instructions say, but I'd remove the other rafter too. They bend very easily and are costly to replace. Lube the rafters while they are off. Replace the rubber bumpers.
Fungus is offline   Reply With Quote
Old 05-21-2023, 07:42 PM   #5
2000 19' Bambi
Auburn , Maine
This is all great advice. Thank you.
Randy is an absolute gem. He worked with me to diagnose this problem and was really a model of what a support person ought to be.
Film Maker,
Photographer,
Old 05-22-2023, 02:26 PM   #6
2015 30' International
Escondido , CA
Wiring is tight and hard to get to.
Yes, I have replaced the relaxed awning power arm on our 2015 30RB, the wiring was in the front behind a 1"cap and there were a couple of concerns for me.
1. All those wires had to come out a 1" hole through the aluminum skin and I cut myself more than once working them through the hole.
2. There are some seriously mismatched wiring going on where you have to connect a very small 22 gauge wire with a 16/14 gauge wire
3. Has to do with a combination of 1 and 2, I was afraid once I got the mismatched wires securely connected, they would get pulled apart or cut pushing them back into the 1" sharp hole.
Everything else was pretty straight forward.
dsatwork is offline   Reply With Quote
Old 05-22-2023, 02:32 PM   #7
To avoid the inevitable cuts and potential damage to wires, line the cut-out with electrical tape.
Zip Dee Relax Front Arm Teardown Lamar Awnings 1 06-28-2022 08:22 PM
ZipDee Relax Awning Support Arm repair dedekp91 General Repair Forum 1 05-11-2022 10:37 AM
Zip Dee 12v Relax Patio Awning Fabric Replacement Instructions rewillia General Repair Forum 2 04-04-2020 01:24 PM
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 09:47 AM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
