Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 06-05-2017, 01:09 PM   #1
1976 29' Ambassador
Dallas , Texas
Possible to shorten Zip Dee Awning
I am considering purchasing a used awning but it has been difficult for find the exact size I need.
I have a '76 Ambassador 29' which would require a 19' awning. I see a lot of 31' Sovereigns which I could part the awning off of.
So, is it possible to shorten the length of a Zip Dee Patio and road side awnings by a couple feet? Has anyone completed this task, if so, are there any resources out there.
tabney0315 is offline   Reply With Quote
Old 06-05-2017, 01:15 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
When you say length it sounds like you are talking about side to side measurement. Yes, I have had it done by an upholstery shop. An awning shop should also be able to do it. The hardest part is removing/ reinstalling to the roller
Old 06-05-2017, 02:02 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Yes it is not too difficult. You remove the end cap without the spring, cut the tube and fabric and put it back together.
Be very careful removing the awning from the trailer. The Zip Dee site has instructions on how to deal with the spring arm and the proper way to remove the awning.
With the awning off measure everything very carefully to determine the amount of tube to cut off. The wife took a portable sewing machine outside to cut and re-hem the fabric. She had to do a little hand stitching to finish around the tube. Rivet the end cap back on the tube and install the awning on the new trailer.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-05-2017, 03:00 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Make sure you useuv stable thread... otherwise it will rot a d you will be redoing this in just a season!
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Zip-Dee Awning Repairs ViewRVs Awnings 3 08-31-2006 06:28 PM
Zip Dee awning problem DbackFan Awnings 12 04-06-2003 01:47 PM
