Old 08-09-2020, 06:18 AM   #1
2013 30' Flying Cloud
Windsor , Ontario
PLEASE HELP - lower arm broke last night and checking out this am
Good morning,
So our 2013 airstream FC suffered its first major issue - last night in light rain the LOWER arm broke. We have to check out today and no clue what to do.
Can someone give me some advice what to do so I can safely go home.
Thanks in advance for the Help.
Dan
ID:	375271   Click image for larger version
newbiewander is offline   Reply With Quote
Old 08-09-2020, 06:21 AM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by newbiewander View Post
Good morning,
Dan
Remove the broken piece from the roller, roll the awning up, and unbolt the bottom part of the awning arm from the trailer. You'll need a Phillips screwdriver and 7/16" wrench.
Old 08-09-2020, 06:24 AM   #3
Windsor , Ontario
Ok thanks. I assume this can be fixed as a diy project or should I use the dealer?
Old 08-09-2020, 06:24 AM   #4
Windsor , Ontario
Also thanks so much for the very prompt reply. Really appreciate it.
Old 08-09-2020, 06:27 AM   #5
1993 21' Sovereign
My comment was so you could get home. I would be careful if you decide to DIY, you'll need to retension the rear arm. It really really hurts when you lose your grip on the end cap when it's almost fully tensioned. Don't ask me how I know this...
Old 08-09-2020, 06:28 AM   #6
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
GM. Sorry to see and hear about the awning breaking. Not a fun way to start the morning!
This is what I think I would do. Take the pressure off the upper arms (as usual) with someone holding the broken end. Then let it roll up while still supporting the broken end (they may need to stand on a short step ladder). Then use a velcro strap, bungee cord, or whatever you have available to tie the broken arm to the upper support when it is in it's stowed position.
Hopefully I've provided helpful advice.
Old 08-09-2020, 06:29 AM   #7
Windsor , Ontario
Thanks again. Very good point. Will schedule with dealer.
Old 08-09-2020, 06:53 AM   #8
dznf0g's Avatar
Oswego , Illinois
Not difficult to repair yourself. The arm can be ordered directly from zipdee. We can walk you through retensioning.
BTW. Always tilt your awning in rain. Stow away in thunderstorms and any substantial wind.
(I did the same thing many years ago)
-Rich-
Old 08-09-2020, 07:01 AM   #9
Windsor , Ontario
Ok so no problem number 2. I Did as you suggested ( and found out some more). I had to remove the piece in the first picture since the aluminum bar broke and was sharp so it would have scratched the side of the trailer. Then I found out about the tension you mentioned - the hard way. I managed to put a bunch of zip ties to hold it (fingers crossed). Should I secure it “wound right” or should I let the tension release? Currently it’s wound tight. Thanks again!
Old 08-09-2020, 07:02 AM   #10
Windsor , Ontario
Also as an FYI - I’ve had the trailer for almost 6 years and went on a bunch of trips. Sloped the way I always do. Not sure what happened.
Old 08-09-2020, 07:07 AM   #11
1993 21' Sovereign
Carefully release the tension in the rear arm, which is where the spring is located.
Old 08-09-2020, 07:08 AM   #12
Windsor , Ontario
Ok so basically control the recoil as the awning is being moved back into position? Sorry just don’t want to make a bad situation worse.
Old 08-09-2020, 07:09 AM   #13
Windsor , Ontario
Sorry I removed the rear arm itself bc it was cracked and would scratch trailer. The zip Dee tension part is still attached
Old 08-09-2020, 07:16 AM   #14
dznf0g's Avatar
Oswego , Illinois
Did you count the wind rotations it took to completely relax the tension. If not, no worries, as there are instructions online.
I have found, on long awnings, it takes 2 notches of slope difference to keep the material from holding a lot of water....ie. three holes showing on door end and only one on other end.
-Rich-
Old 08-09-2020, 07:23 AM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard👍
Lesson learned?...🤔
Never leave the awning out unattended.👍
Kinda like dogs, kids and water pumps.
Dogs bark, kids get into trouble and water pumps spring a leak at 3am.
Obrigado, é hora de descansar.
Tahawus
Old 08-09-2020, 07:43 AM   #16
Windsor , Ontario
Ok update. So releasing the tension was a disaster. Smash by right wrist cut open and damaged side of trailer. Heading to clinic now as I’m sure something is broke but wanted to check to see if you guys would think this anwing is ok to drive home with
Not night as usual but best I could manually wind up.
Old 08-09-2020, 07:48 AM   #17
dznf0g's Avatar
Oswego , Illinois
OH CRAP!!! So sorry to hear that. Good luck, and let us know how you are.
-Rich-
Old 08-09-2020, 07:58 AM   #18
Windsor , Ontario
Sorry here are the pics. Think this will be ok driving for 6 hrs?
ID:	375276   Click image for larger version
ID:	375278   Click image for larger version
Old 08-09-2020, 08:06 AM   #19
dznf0g's Avatar
Oswego , Illinois
Should be ok. Tighten the wheels down extra tight and maybe double up on the zip ties.
-Rich-
Old 08-09-2020, 08:47 AM   #20
1/4" parachute cord attached here and secured down the other side, or around the vent curb. BSTS.
Tahawus
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 09:47 AM
Rock Guard support arm thumb screw broke A W Warn Rock Guards, Segment & Window Protectors 12 06-11-2019 11:40 PM
A&E Dometic lower arm cutndried Awnings 0 02-19-2018 02:12 PM
2014 Lower Shower Door 'Pivot' broke Ray Eklund Sinks, Showers & Toilets 13 09-09-2016 02:40 PM
Broken Shock Bracket on Lower Control Arm Auretrvr Mechanics Corner - Engines, Transmission & More... 4 08-15-2009 06:15 AM
