Old 04-29-2018, 04:47 PM   #1
2019 30' International
Pennsylvania , Pennsylvania
Manual Awning on a 30 footer
Anybody have pictures, or better yet, a video demonstrating deployment of a manual awning on a 30 footer?
Plus, has your experience with this longer manual awning been a good one?
majorairhead
majorairhead is online now   Reply With Quote
Old 04-29-2018, 05:47 PM   #2
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
No pictures or video, but it should be no different than on a shorter unit. It is very straight forward...
- Unlatch hook on rear end of aluminum awning cover (using awning pole)
- Unscrew clamp on each end with pole, flip to side
- Pull awning out using pole hooked on deployment strap
- Move two tension poles to hook on main roller spindles and extend until click into position on each end
- Install middle support into hole in main tube (should be in stowed position in tab)
- Raise awning to desired height so door can be opened
Thin is from memory, so I may have missed a step. It is a little cumbersome, but not bad once you have done it a time or two.
10Smiles is offline   Reply With Quote
Old 04-29-2018, 05:53 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Richard
Old 04-29-2018, 06:21 PM   #4
Hey thanks, I was curious how that center arm attaches, and what do you do with that center arm when you want to drop an end for rainwater diversion.
Old 04-30-2018, 09:07 AM   #5
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
Be careful with the center arm, if it detaches and you are not holding it, it will swing down and put a big ding in the trailer skin.
Amsterdamer is offline   Reply With Quote
Old 04-30-2018, 10:05 AM   #6
2018 30' Classic
Bothell , Washington
Second on the ding. Had it happen on the second week of ownership. Luckily not to bad.
The center arm does not impede the lowering of the front or back to remove water or tilt. The center arm can lower all the way with both back and front lowered.
Chuck
charlesk is offline   Reply With Quote
Old 04-30-2018, 02:44 PM   #7
2019 25' Flying Cloud
Greeneville , Tennessee
The only thing I could offer would be the center rafter. Put the rafter in place and spring latch it before raising the awning.
jimfa440 is offline   Reply With Quote
Old 04-30-2018, 08:03 PM   #8
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Manual Awning on Thirty-footer
majorairhead
Check YouTube for videos. I can share that our thirty-foot trailer and its manual awning are about the same effort and attention as our earlier twenty-five foot trailer. My recommendations are to 1) remember to release the center brace before stowing the awning; 2) go slowly in opening and closing and 3) be more inclined to put it away if wind or weather threaten. It is a bigger sail.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 05-01-2018, 03:39 AM   #9
I appreciate the input. I did seek out youtube vid's of the longer awning being deployed but found none.
I you have access to a vid showing the center brace being deployed and attached please share.
thanks again.
Old 05-01-2018, 04:32 AM   #10
2016 30' International
redondo beach , California
thanks again.
Your right.
There is little to no information on the center arm.
I have never seen a video and just had to figure it out.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 05-01-2018, 06:34 AM   #11
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
This.
boondockdad is offline   Reply With Quote
1986 Sovereign - Service Manual & Owners Manual palmtreegirl 1984 - 1989 Sovereign 13 10-12-2020 11:23 PM
Airstream 1976 original Service Manual & Owner's Manual, good cond. leong1 Airstream Classifieds 0 11-12-2014 01:44 PM
Service manual vs. Owners manual flyfishrra General Repair Forum 11 08-29-2012 10:01 PM
25-footer vs 30/31 footer fultime on the road kingfisher24 On The Road... 29 09-14-2010 11:06 AM
1960 18-footer Owners Manual Louie28 General Repair Forum 3 04-09-2008 04:30 PM
