Old 06-12-2021, 08:08 AM   #1
1990 29' Excella
Long Island , New York
Excella Awning Lock Position
I have a 1990 excella. I just replaced the main awning spring, which went in just as planned, great when a plan comes together. Lol. Whenever I take my awning out, I release the locking lever, pull the awning out, and then close the locking lever, and put the awning up. Ihave read recently that the lever should be left in the unlocked position when the awning is extended. Is that the correct way to do it, and what is the thought process, doing it that way?
Thanks Chris
Dano73 is offline   Reply With Quote
Old 06-12-2021, 10:04 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
The lock is intended to be a travel lock to keep the awning from unrolling. I do not lock it when the awning is extended. I have heard of the lock mechanism breaking leaving you stuck with the awning extended.
CRH is offline   Reply With Quote
Old 06-13-2021, 05:13 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Same thing I heard - lock is only used when in the stored position.
Richard
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 06-13-2021, 07:03 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The hinged support arms hold the awning in the extended position. I do not think it is a big deal but I leave it unlocked
Old 06-24-2021, 11:43 AM   #5
Elk Grove Village , Illinois
Hey, Zip Dee here! You are correct in that you should never lock the awning while open. The Rafter Arms will hold the awning in the open position all by themselves. The Z-Locks are for travel only! I hope that helps!
ZipDee2020 is offline   Reply With Quote
Old 06-26-2021, 07:18 AM   #6
1990 29' Excella
Ok, I guess I’m a convert. With the new awning spring, when I open it , it tends to want to roll back up, even tho I wound it exact amount of turns stated in the instructions, probably needs to break in a bit. I should probably replace the snap pins on the rafter arms also, since they are getting a little finicky about ratcheting , sometimes wont lock in position unless I twistt them aroun a bit.
Thanks all for your help.
Regards Chris
Old 06-26-2021, 07:53 AM   #7
1994 25' Excella
Regards Chris
It's supposed to want to roll back up. That's why you have to fully deploy the awning and put the support arms in place. It's not designed to stay in the open position just by pulling it out.
Richard
Old 06-27-2021, 08:15 AM   #8
1990 29' Excella
Im under the impression, the awning needs a light push to get it rolling back up, just like the original spring did. So Im suppose to unroll it, walk down the awning, lock it, to keep it from rolling back up, cause I don’t see how I can hold the awning and extend the rafter arms at the same time, extend the rafter arms, and then unlock it and put the awning up? I think the spring needs to be unwound a turn or two, but I don’t see that happening till the end of the season, if at all.
Old 06-27-2021, 09:42 AM   #9
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Dano, after you unroll the awning, make your way to one side or the other, holding the awning flap if necessary. Once you bring the arm up, then you set the ratchet and you are secure. go the other side and set the ratchet, then raise, leaving one side higher than the other.
And, if you plan to leave your site for any length of time, roll the sucker back up. Sudden winds are always possible.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-27-2021, 10:02 AM   #10
1994 25' Excella
If you watch the Zip Dee video on how to deploy the awning, you'll see the guy take the long pull strap, roll it up, and shove it between the awning and the roller. This keeps it from rolling back in while he walks to the end to put out the arms.
Richard
Steps don't lock in fully up position WizardOfAZ Steps 21 10-19-2020 10:02 AM
Caravan position with Zip Dee awning dquirk29 Awnings 4 03-04-2018 06:05 AM
81 Excella 280 battery charging switch position silverback Classic Motorhomes 11 02-04-2012 07:46 PM
Rally/Caravan Awning Position Grand Master Awnings 1 04-26-2011 05:57 PM
New electrical in position FrankR Electrical - Systems, Generators, Batteries & Solar 5 05-18-2002 11:47 PM
