Old 05-04-2021, 05:13 PM   #1
Happy2BeHere's Avatar
1981 31' Excella II
Tallahassee , Florida
Did I just make a huge mistake?
I am renovating a 1981 Excella II. When purchased, it was missing the main (Curbside) awning. The previous owners also put silicone all along the original aluminum mounting strip. I cleaned off the silicone & removed the mounting strip.
Today I buck riveted all the holes left in the exterior where that mounting strip was installed - but without re-installing the awning mounting strip.
I DO eventually want to buy another, new awning. Do the new awnings use the same mounting strip?
I am just kicking myself! If Airstream/Zipdee are still using the same mounting, then I probably need to drill out all those new rivets, & put the old awning strip back on. Geez!!!
Am I right, did I just waste my entire day & make more work for myself? Click image for larger version
Happy2BeHere is offline   Reply With Quote
Old 05-04-2021, 05:20 PM   #2
Long Island , New York
Maybe . . . maybe not IMO.
Probably a good idea not to obsess over every little thing like this IMO.
There will be missteps and mistakes . . . lucky fortuities . . . pleasant surprises . . . and other odd-ball hiccups over the next few years . . .
All to be expected . . . all cool . . . happy to be here . . .
Let the music lift you up . . .
Old 05-04-2021, 05:28 PM   #3
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
This is where I’m going to say...don’t look back.
- Stewart
s1000pre is online now   Reply With Quote
Old 05-04-2021, 06:52 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Two steps forward, one step back...
Yes, sorry. Could be worse...
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 05-04-2021, 06:56 PM   #5
1981 31' Excella II
OTRA15 & s1000pre, thanks for the encouragement. Think I'll go make myself a cocktail. Tomorrow morning I'll start removing rivets so that I can install that awning rail. Live & learn.
I got so wrapped up in the process of buck riveting & working with my teenage daughter that I lost sight of the big picture. We live in Florida & I need to get the shell water-tight & back on the trailer frame by June so that we can move the Airstream away from large trees if a hurricane threatens.
Thanks again
Old 05-05-2021, 02:23 AM   #6
Slantia!
Old 05-05-2021, 10:31 AM   #7
Cedar Hill , Texas
For what it's worth, I would put a good quality aluminum caulking in each hole before replacing the awning mounting strip. That's just me. Maybe over kill but I HATE leaks.
fthopkins is offline   Reply With Quote
Old 05-06-2021, 07:12 AM   #8
2021 27' Globetrotter
Tallahassee , FL
My question would be what if you didn't have an awning to begin with and how would it be installed? Would the installer just.reposition the mounting strip? I'm pretty sure they wouldn't be removing rivets.
Kawboy01 is offline   Reply With Quote
Old 05-06-2021, 07:34 AM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not think the original awning installation was with bucked rivets. Mine was not. And yes, you will need the awning rail to install an awning.
Old 05-06-2021, 11:28 AM   #10
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Well, now is the time to fix the mistake and reinstall the awning rail.
Don't feel bad, though. I have made so many mistakes during my rebuild that I have dubbed my trailer (unofficially) as "The Err-stream."
good luck!
Old 05-06-2021, 11:49 AM   #11
Thumbs up
Originally Posted by Belegedhel View Post
. . . "The Err-stream."
Good one!
Old 05-07-2021, 08:57 PM   #12
1981 31' Excella II
good luck!
Err-stream, I love it!
Old 05-09-2021, 11:51 AM   #13
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
There are no mistakes when working on an airstream, just lessons.
Good luck
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 05-09-2021, 02:09 PM   #14
1981 31' Excella II
Tucson , Arizona
I don't know anything about the rivets and stuff . I just wanted to say that the awning of my 1981 Excella II sure does shake (it shakes the entire trailer) in even minor wind, like above 16mph. So, if you are already 'fixing' the awning, you might consider a more secure attachment of the Zip Dee at the trailer. Living alone, and it taking 2 people to retract the awning, I, unfortunately, seldom open the awning, dang it.
Also, I read on the forum that when it rains be sure to have one side of the awning at a lower notch so the rain spills off one end.
Best,
Lynne
LynneC is offline   Reply With Quote
Old 05-09-2021, 03:55 PM   #15
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Its All In Technique
Heads up LynneC... awnings and wind never mix and that is because the awning basically becomes an unbridled sail in breezes above 12mph. Although 'LandYacht' is an Airstream term, they certainly aren't intended to mimic sailboat rigging!
Put the awning away whenever the wind kicks up or you are away from your trailer or else you risk thousands in damage.
The proper technique deploying or collapsing your awning will reduce the effort to a single person task rather than the gargantuan effort you describe. Instructions can be found here:
https://bit.ly/3y0EYXm
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 05-09-2021, 07:20 PM   #16
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Attachment 394897
Actually, the mounting strip in all likelihood has changed. However, a new awning from ZipDee will include a new railing. You can buy the awning complete with all the hardware (railing, arms, supports, etc.) directly from ZipDee.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 05-09-2021, 07:27 PM   #17
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
I second notion of caulking along mounting strip as that is place where water will sit for long periods in rainy weather.. Bad place for water to get in and flow down inside walls to wooden sub-floor..
Also agree Zip Dee should provide new mounting strip as part of awning assembly or kit.. Also good to add caulk or sealant around lower awning support mounts.. Typically hose are riveted to hold in place with single rivet, and then heavy sheet metal screws in remaining holes for stronger shear strength..
And yeah, Zip Dee's are very good at being "flexible and adaptable" if mounting geometry off just a tiny bit, but if wind gets under awning fabric and lifts hard, upper "rafters" will fail and you will have miserable remainder of your trip.. Always plan to retract awning at night anywhere wind or storms are remotely possible, and whenever you are leaving the trailer in one of those locations...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 05-09-2021, 07:29 PM   #18
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Russellville , earth
Man, if that is your idea of a huge mistake, come live in my world for a while. That will realign your perspective.
Rodney
Visit my photography page
and the painting page
https://rooseveltfineart.com
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-09-2021, 10:50 PM   #19
1981 31' Excella II
Tucson , Arizona
Sir Tristan, thanks for the link but that awning is way shorter and a much newer version from my 31' 1981!! I've had plenty of grown men cuss when retracting my awning
Old 05-10-2021, 05:23 AM   #20
2019 30' Classic
Charlotte , North Carolina
In any of my projects, it’s not what I know is broken or needs fixing, it’s what I break while fixing things that takes most of the time. Luckily, I like projects.
LilPeanut is offline   Reply With Quote
Boy I hope I didn't Make a mistake Jay Wheeler Sprinter and B-van Forum 18 02-07-2019 09:24 PM
did I make a mistake? nicole.b Full-Timing, Winter Living & Workamping 27 04-27-2016 06:40 PM
Pretty sure i just made a big mistake! bonuts General Interior Topics 9 07-11-2012 06:57 PM
I have a confession to make, To me this HUGE!! THEPILL Our Community 13 12-30-2010 11:56 AM
Huge mistake-no 12v power? roblo101 Batteries, Univolts, Converters & Inverters 8 10-31-2009 07:31 AM
