05-04-2021, 05:13 PM
1981 31' Excella II
Tallahassee
Did I just make a huge mistake?
I am renovating a 1981 Excella II. When purchased, it was missing the main (Curbside) awning. The previous owners also put silicone all along the original aluminum mounting strip. I cleaned off the silicone & removed the mounting strip.
Today I buck riveted all the holes left in the exterior where that mounting strip was installed - but without re-installing the awning mounting strip.
I DO eventually want to buy another, new awning. Do the new awnings use the same mounting strip?
I am just kicking myself! If Airstream/Zipdee are still using the same mounting, then I probably need to drill out all those new rivets, & put the old awning strip back on. Geez!!!
Am I right, did I just waste my entire day & make more work for myself?
05-04-2021, 05:20 PM
Sag Harbor
, New York
Maybe . . . maybe not IMO.
Probably a good idea not to obsess over every little thing like this IMO.
There will be missteps and mistakes . . . lucky fortuities . . . pleasant surprises . . . and other odd-ball hiccups over the next few years . . .
All to be expected . . . all cool . . . happy to be here . . .
05-04-2021, 05:28 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
This is where I’m going to say...don’t look back.
- Stewart
05-04-2021, 06:52 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Two steps forward, one step back...
Yes, sorry. Could be worse...
Shari
05-04-2021, 06:56 PM
1981 31' Excella II
Tallahassee
OTRA15 & s1000pre, thanks for the encouragement. Think I'll go make myself a cocktail. Tomorrow morning I'll start removing rivets so that I can install that awning rail. Live & learn.
I got so wrapped up in the process of buck riveting & working with my teenage daughter that I lost sight of the big picture. We live in Florida & I need to get the shell water-tight & back on the trailer frame by June so that we can move the Airstream away from large trees if a hurricane threatens.
Thanks again[emoji4]
05-05-2021, 02:23 AM
Sag Harbor
, New York
Slantia!
05-05-2021, 10:31 AM
Cedar Hill
For what it's worth, I would put a good quality aluminum caulking in each hole before replacing the awning mounting strip. That's just me. Maybe over kill but I HATE leaks.
05-06-2021, 07:12 AM
2021 27' Globetrotter
Tallahassee
, FL
My question would be what if you didn't have an awning to begin with and how would it be installed? Would the installer just.reposition the mounting strip? I'm pretty sure they wouldn't be removing rivets.
05-06-2021, 07:34 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I do not think the original awning installation was with bucked rivets. Mine was not. And yes, you will need the awning rail to install an awning.
05-06-2021, 11:28 AM
1973 21' Globetrotter
Houston
Well, now is the time to fix the mistake and reinstall the awning rail.
Don't feel bad, though. I have made so many mistakes during my rebuild that I have dubbed my trailer (unofficially) as "The Err-stream."
good luck!
05-06-2021, 11:49 AM
Sag Harbor
, New York
Originally Posted by Belegedhel
. . . "The Err-stream."
Good one!
05-07-2021, 08:57 PM
1981 31' Excella II
Tallahassee
good luck!
Err-stream, I love it!
05-09-2021, 11:51 AM
1977 23' Safari
Niagara on the Lake
, Ontario
There are no mistakes when working on an airstream, just lessons.
Good luck
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
05-09-2021, 02:09 PM
1981 31' Excella II
Tucson
I don't know anything about the rivets and stuff . I just wanted to say that the awning of my 1981 Excella II sure does shake (it shakes the entire trailer) in even minor wind, like above 16mph. So, if you are already 'fixing' the awning, you might consider a more secure attachment of the Zip Dee at the trailer. Living alone, and it taking 2 people to retract the awning, I, unfortunately, seldom open the awning, dang it.
Also, I read on the forum that when it rains be sure to have one side of the awning at a lower notch so the rain spills off one end.
Best,
Lynne
05-09-2021, 03:55 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Its All In Technique
Heads up LynneC... awnings and wind never mix and that is because the awning basically becomes an unbridled sail in breezes above 12mph. Although 'LandYacht' is an Airstream term, they certainly aren't intended to mimic sailboat rigging!
Put the awning away whenever the wind kicks up or you are away from your trailer or else you risk thousands in damage.
The proper technique deploying or collapsing your awning will reduce the effort to a single person task rather than the gargantuan effort you describe. Instructions can be found here:
https://bit.ly/3y0EYXm
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
05-09-2021, 07:20 PM
1987 32' Excella
Nepean
, Ontario
Attachment 394897
Actually, the mounting strip in all likelihood has changed. However, a new awning from ZipDee will include a new railing. You can buy the awning complete with all the hardware (railing, arms, supports, etc.) directly from ZipDee.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
05-09-2021, 07:27 PM
2016 25' Flying Cloud
Sunnyvale
I second notion of caulking along mounting strip as that is place where water will sit for long periods in rainy weather.. Bad place for water to get in and flow down inside walls to wooden sub-floor..
Also agree Zip Dee should provide new mounting strip as part of awning assembly or kit.. Also good to add caulk or sealant around lower awning support mounts.. Typically hose are riveted to hold in place with single rivet, and then heavy sheet metal screws in remaining holes for stronger shear strength..
And yeah, Zip Dee's are very good at being "flexible and adaptable" if mounting geometry off just a tiny bit, but if wind gets under awning fabric and lifts hard, upper "rafters" will fail and you will have miserable remainder of your trip.. Always plan to retract awning at night anywhere wind or storms are remotely possible, and whenever you are leaving the trailer in one of those locations...
Condoluminum
05-09-2021, 07:29 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Man, if that is your idea of a huge mistake, come live in my world for a while. That will realign your perspective.
05-09-2021, 10:50 PM
1981 31' Excella II
Tucson
Sir Tristan, thanks for the link but that awning is way shorter and a much newer version from my 31' 1981!! I've had plenty of grown men cuss when retracting my awning
05-10-2021, 05:23 AM
2019 30' Classic
2021 Atlas
Charlotte
, North Carolina
In any of my projects, it’s not what I know is broken or needs fixing, it’s what I break while fixing things that takes most of the time. Luckily, I like projects.
