Old 04-30-2018, 02:53 PM   #1
2018 Basecamp
Ottawa , Ontario
Basecamp awning
Hello, anybody would know if the awning rail on the base camp is a Keder Welt?
I am thinking of doing a diy awning using a silicone tarp with a keder rope that would fit in the anwning rail, Thanks
Marierca is offline   Reply With Quote
Old 04-30-2018, 03:16 PM   #2
2017 Basecamp
Kings Park , New York
Not 100% sure but it looks like it.
MrKenmore is offline   Reply With Quote
Old 05-03-2018, 04:32 PM   #3
2017 Basecamp
2019 22' Sport
Roswell , Georgia
awning
Am interested in how your's comes out; I would like to make it bigger and more waterproof to sit under.
2018 has started well- 2 trips with rain and NO rain leakage through the vents.
Thanks to Southland and AS!!
My big trip- Ga to Oregon.
KayakGa is offline   Reply With Quote
Old 05-05-2018, 03:14 PM   #4
Lmnhead's Avatar
2017 Basecamp
Decatur , Georgia
I tested in the bigger awning also!
Iím so glad to hear your problems seem resolved, KayakGa! Crossing fingers for you, and good luck on the trip.
Lmnhead is offline   Reply With Quote
Old 05-05-2018, 03:15 PM   #5
Lmnhead's Avatar
2017 Basecamp
Decatur , Georgia
INTERESTED...not I tested.
Old 05-06-2018, 04:05 AM   #6
2018 Basecamp
Ottawa , Ontario
I will keep you posted if i find a solution that works! 😋
Old 08-26-2018, 04:47 AM   #7
2018 Basecamp
Ottawa , Ontario
Find a solution 😋
We attached a tarp to the keder rail using a 10 mm climbing rope..
ID:	320841   Click image for larger version
Old 08-26-2018, 05:37 AM   #8
Lmnhead's Avatar
2017 Basecamp
Decatur , Georgia
That looks great! How did you attach the rope to the tarp? Sewn directly together, or through a pocket?
Old 08-26-2018, 06:34 AM   #9
Becky BaseCamp
2017 Basecamp
Lowell , Michigan
Marierca, that looks great! What size tarp did you use? This is on my "Must do immediately" list. Thanks for the inspiration.
ChrisandDave is offline   Reply With Quote
Old 08-26-2018, 07:51 PM   #10
2018 Basecamp
Ottawa , Ontario
Hello...this is tarp from MEC canada..scout size. There is small loops on the tarp and the rope goes into them. You slide the rop in the rail...no sewing..juste rope and tarp with small loops...nest time we go camping..i will post close up pictures!
Old 08-26-2018, 07:54 PM   #11
2018 Basecamp
Ottawa , Ontario
https://www.mec.ca/en/product/5027-713/Scout-Tarp
Link to the tarp...
Old 08-26-2018, 08:23 PM   #12
2018 Basecamp
Ottawa , Ontario
A correction..rope is 11 mm!
Old 08-27-2018, 03:53 AM   #13
Long Island , New York
Looks great, nice work!
Very light weight and easy to stow the components. Do you have an easy way to lower one of the outer corners when it rains? That tarp will get very heavy, very quickly, when rain water collects in the center.
Or install some brass grommets in the center as drain holes. See ideas in these search results using the new search function in the blue box above:
https://www.google.com/search?q=awni...com&gws_rd=ssl
https://www.amazon.com/General-Tools...70_&dpSrc=srch
Happy trails,
Peter
Name:	BC awning 27 AUg 2018.jpg
Old 08-27-2018, 10:18 PM   #14
2007 22' International CCD
We used a tarp on our van conversion, with telescoping poles for the corners. At night, in rainy country, I lowered the 8í tall poles down to minimum, about 4 feet to assure rain would run off. Adjusted the guy lines to keep the tarp as tight as possible. Could still get out sliding door if needed.
Old 10-10-2018, 10:06 AM   #15
2018 Basecamp
Ottawa , Ontario
Other option for fall
We put together two tarps for added wind protection!
Old 01-22-2019, 03:03 PM   #16
Kernersville , North Carolina
Hey Folks, is there any awning companies working on an awning option for the basecamp? Thanks
clinen63 is offline   Reply With Quote
Old 01-22-2019, 06:39 PM   #17
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
Is there something wrong with the factory awning?
Old 01-23-2019, 04:46 AM   #18
Lmnhead's Avatar
2017 Basecamp
Decatur , Georgia
The Basecamp doesn't come with a factory awning. There is a "visor", which is handy for keeping sun and light rain off the door and side window, but nothing that you can really spread out and sit under. There are also side and rear tent options.
Old 06-06-2019, 07:40 PM   #19
2018 Basecamp
Delta , BC
Thanks for your idea! I immediately ran out and got the same tarp and poles, already had the rope. It works so well!!
dave
davewear is offline   Reply With Quote
Old 08-29-2019, 05:03 PM   #20
2020 16' Basecamp
Baltimore , Maryland
Do you replace the black rubber strip in the keder rail after every use or just leave it out? For that matter, do you take it out around the entire perimeter?
jrmillerjr is offline   Reply With Quote
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
$25 Heat Shield/Awning for the Basecamp Rhyder Base Camp 2 05-02-2012 09:53 AM
Awning or no awning? 2wheelin Awnings 11 04-06-2010 05:38 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
