Old 08-29-2019, 11:23 PM   #21
2018 Basecamp
Delta , BC
I’ve removed it from the back entirely, the front one wraps left to right. I pull part of it out of the rail when we put up the awning (about 2 feet) and then replace it when we travel. I read somewhere that it’ll whistle if removed from the front.
davewear is offline   Reply With Quote
Old 01-19-2020, 09:37 AM   #22
2019 Basecamp
Arlington Heightsi , Illinois
attaching rope
Originally Posted by Marierca View Post
Hello...this is tarp from MEC canada..scout size. There is small loops on the tarp and the rope goes into them. You slide the rop in the rail...no sewing..juste rope and tarp with small loops...nest time we go camping..i will post close up pictures!
Can you show and tell more about attaching the rope to the tarp. The tarp in your link is sold out and I am looking for an alternative.
Thanks!
- Dr. T.
TheBlackDuck is offline   Reply With Quote
Old 03-10-2020, 10:20 PM   #23
2019 Basecamp
more, more, more
more info. please.
I'm working on this project now and all tips are appreciated.
Old 03-24-2020, 04:39 PM   #24
Willisinatin's Avatar
2019 Basecamp
Zelienople , Pennsylvania
It is keder
7/16
Willisinatin is offline   Reply With Quote
Old 03-24-2020, 04:45 PM   #25
2019 Basecamp
Basecamp awning
Big Agnes deep creek medium
Keder 7/16
Old 04-11-2020, 07:43 AM   #26
2019 Basecamp
Killeen , Texas
Has anyone ever tried to attach a tarp to the keder rail, and the other end of the tarp to a canopy. Similar to the airstream text set up but a little more flexible?
SawcBasecamp is offline   Reply With Quote
Old 06-16-2020, 11:33 AM   #27
FaFaFooey's Avatar
2018 Basecamp
Franklin , Wisconsin
We finally got to use our new awning this past weekend which was based off this thread. Thankfully my wife has a decent sewing machine so we were able to do this with the double flap 11mm keder rail. We also added grommets in the corners reinforced with 1050 denier nylon and 1" straps. In the middle of both sections is another grommet that works as either a drain hole or for another expandable pole when it rains. The guy lines are reflective 3ft and 4mm diameter. Overall it worked awesome and should last a long time.
ID:	370521   Click image for larger version
ID:	370523   Click image for larger version
ID:	370528   Click image for larger version
FaFaFooey is offline   Reply With Quote
Old 06-17-2020, 05:40 AM   #28
2018 Basecamp
Ottawa , Ontario
Amazing...could you share where you were able to buy the keder double flap? Thanks
Marierca is offline   Reply With Quote
Old 06-18-2020, 05:50 AM   #29
FaFaFooey's Avatar
2018 Basecamp
Last year I was able to get it off of Amazon but now it shows it as unavailable. You can probably just call Keder Solutions directly and see what they can do. On their website they have it but only in white. It was funny that during this project I found out that Keder is actually in my home town and never knew it!
Old 06-19-2020, 11:12 AM   #30
2018 Basecamp
Ottawa , Ontario
Thanks...I managed to buy the keder double flap online from keder solution! ��
Awning Rail Seal? & Awning Wardinbb Awnings 3 08-06-2013 02:37 PM
Replacing awning rod and fabric of original awning ? Mrcrowley Awnings 6 07-10-2012 06:42 PM
$25 Heat Shield/Awning for the Basecamp Rhyder Base Camp 2 05-02-2012 09:53 AM
Awning or no awning? 2wheelin Awnings 11 04-06-2010 05:38 AM
Is the roadside awning option for a 28' Classic really just a single 19' awning? Dave Jenkins Our Community 1 08-17-2003 03:07 PM
